23105 Discussions
I don't have "on". Only application settings and driver settings .
khkoy
Wanner_G_Intel
Hello khkoy,
Thank you for submitting your question on this Intel® Community.
To better assist you, we would like to have more information about your system configuration:
Please generate a system report with the Intel® System Support Utility (Intel® SSU) and attach it to this thread.
  1. Intel® SSU Download link
  2. Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  3. Click on the menu where it says "Summary" to change to "Detailed View".
  4. To save your scan, click on "Next", then "Save".
Please generate a DxDiag* report, too.
  1. Go to Start > Run or Windows Key + R.
  2. On the Run prompt, type "dxdiag" then click OK.
  3. On the DirectX Diagnostic Tool window, click on Save All Information.
  4. Browse to a folder, type in a filename then click Save.
Is this setting present on the Intel® Graphics Command Center?
Note: Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool embedded on this Intel® Community.
Wanner G.
Max44
Open DirectX diagnostics by going to Run –> dxdiag.
Go to Display.
Under the Drivers section, note down the Version number.
Open Windows Registry Editor by going to Run –> regedit.
In the right-hand pane, open DriverVersion key and replace its value with the one which we extracted in step no.
Wanner_G_Intel
Hello khkoy,
If you need further assistance, please let us know. We will be glad to assist you.
Wanner G.
Wanner_G_Intel
Hello khkoy,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Wanner G.
