23735 Discussions
Intel Driver and Support assistant : Sorry, something went wrong while trying to scan.
User1582991237507479
I have had this problem for atleast 4 months now and I've tried reinstalling it over and over again. But to no avail. I have also looked at other forums about this problem, but none have a working solution.
AlHill
Just download the graphics driver and install it. Do this until IDSA is fixed.
Doc
AndrewG_Intel
Hello User15829912375074790708
In order to check this behavior further, could you please provide the following information?
1- Intel® Driver & Support Assistant (Intel® DSA) logs files. They are located at "C:\ProgramData\Intel\DSA". This folder is usually hidden (hidden Windows folder). There are 2 methods to get the logs:
1.1- Press "Windows Key + R" and in the Run box type in "C:\ProgramData\Intel\DSA", copy all the files to another folder as a zip file.
1.2- Go to Local Disk (C:), on the Window menu, click on "View tab", check "Hidden item", now "ProgramData" folder should be visible, Go "ProgramData >> Intel >> DSA", copy all the files to another folder as a zip file.
Please attached the zip folder with all the files.
2- Which Browser is Intel® DSA using to scan? Have you tried different browsers?
3- Please run the Intel® System Support Utility (Intel® SSU) and attach the report to this thread.
3.1- Download the Intel® SSU and save the application on your computer.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
3.2- Open the application and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
3.3- To save your scan, click Next and click Save.
Note: To attach a file, you must click the “Attach” option on the bottom left-hand corner of the response box.
Andrew G.
Hello AndrewG
The files that you have requested are down below and i have tried microsoft edge and google chrome.
Thank you in advance
AndrewG_Intel
Thank you for your response.
We would like to inform you that we just released yesterday a new version of Intel® DSA, version 20.2.9.6.
Could you please try the following steps and let us know if the issue is solved:
1- Uninstall the previous version of Intel® DSA from Windows® Apps & Features.
2- Run the Intel® Driver & Support Assistant Uninstaller.
3- Clear Browser cache.
4- Install the new version of the Intel® Driver & Support Assistant Version: 20.2.9.6.
If the issue persists after scanning with the new version, please kindly gather and provide a new zip file with all the files located at "C:\ProgramData\Intel\DSA" so we can investigate further using both zip files with the previous version and newer version.
Andrew G.
Hello AndrewG
The newest version of the Intel® Driver & Support Assistant version: 20.2.9.6 works for me now.
Thank you for your assistance.
AndrewG_Intel
We are glad to know that the new version of Intel® DSA is working now. We will proceed to close this inquiry but if you need assistance in the future, please do not hesitate to contact us back.
Andrew G.
Max44
I would suggest you turn the firewall off through Windows Defender Security Centre:
- Open Settings
- Select Update & Security
- Select Windows Security (left-hand side)
- Select Firewall & network protection (under the Protection areas heading)
- Select Domain network/private network/public network
- Toggle the switch to Off under the Windows Defender Firewall heading
- Note: you will need to do this for all three networks (domain, private, public)
Thank you for your advice, but the new version of the Intel® Driver & Support Assistant works again.
