22933 Discussions
I have Intel HD Graphics 3000 card, discontinued by Intel. Running on Windows 10, with the last compatible Intel driver (9.17.10.4459, dated 5/19/2016). Does not seem able to support a game requiring DX11 Feature Level 10? Advice?
RPris
My OS has DirectX 12. I can't find any newer drivers for the card. Is a newer graphics card the only solution?
AlHill
Your graphics are not supported on Windows 10. You are using the Microsoft generic driver, which lacks features and performance.
Advice? Upgrade to new hardware that is supported on Windows 10.
Doc
RPris
Thank you; I was afraid so.
Andre303
I have the same problem, but I've been trying for months and I can't seem to fix it. What do you mean by dox?
Please explain I'm really bad with computers.
AlHill
If you have the same problem, the answer is the same.
What do you mean by "dox"?
BHarr8
Valued Contributor I
You might be able to use the Windows 8.1 version of the drivers and disable driver updates. This seems to have worked here:
NEED Windows 10 64-bit Driver for Intel HD 3000 - Page 3 - Windows 10 Forums (tenforums.com)
Maiti
Nesecito los driver para
IntelHD Graphics 3000 9.17.10.4459
