22963 Discussions
I have a Intel HD Graphics 520 Display adapter. I want to set up 3 screens, laptop + 2 externals. One screen is no problem, but the second does not work.
HSmit27
I have seen on the posts that it is not advisable to use adapters, however I do not have a choice. Unfortunately nothing I do seems to work. Do you have any advise on what to try?
AlHill
Three screens on what? provide the model number of your laptop or system/
Provide your processor model number.
Provide your Windows 10 VERSION (1909 fpr example)
Doc
HSmit27
Hi. Fijitsu Lifebook E Series
HSmit27
I See the picture didnt send...
Windows 10 Enterprise
Processor Intel Core(TM) i5-6300U CPU @2.40GHz 2.50Ghz
12 Gb RAM
System type: 64 - bit OPerating system, x64-based processor
HSmit27
Windows 10 Enterprise 2018...
AlHill
That is not the W10 version number. Go to start, settings, system, about, and get the version number.
Doc
HSmit27
OS Name Microsoft Windows 10 Enterprise
Version 10.0.17134 Build 17134
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name MD2ET2AC
System Manufacturer FUJITSU
System Model LIFEBOOK E746
System Type x64-based PC
System SKU SK00
Processor Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz, 2501 Mhz, 2 Core(s), 4 Logical Processor(s)
BIOS Version/Date FUJITSU // Insyde Software Corp. Version 1.32, 2018/04/26
SMBIOS Version 2.8
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer FUJITSU
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Mobile
Secure Boot State Unsupported
PCR7 Configuration Binding Disabled by Policy
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume2
Locale South Africa
Hardware Abstraction Layer Version = "10.0.17134.1098"
AlHill
You are on version 1803, which is March 2018.
Whatever the case, you should upgrade to 1909:
https://www.microsoft.com/en-us/software-download/windows10
Doc
n_scott_pearson
Back to the actual problem, it appears that the VGA and DP connectors are exclusive (i.e. you can use only one of them). To get a third display, you may be able to use a DisplayPort MST Hub to connect two displays. Here are some examples:
For DisplayPort monitors: https://www.amazon.com/Monoprice-2-Port-DisplayPort-Multi-Stream-Transport/dp/B075754ZYC
For HDMI monitors: https://www.amazon.com/C2G-54293-DisplayPort-Monitor-Splitter/dp/B07S3257HQ
Note that, if these work, you are sharing the bandwidth of the single DisplayPort channel across the two monitors. I would stick to 1080p or similar monitors. You should be able to go up to 4K @30Hz but, well, ...
Hope this helps,
