21224 Discussions
I installed Windows 10. Intel HD graphics 4000 driver (latest from June 2015) is not accepted by Windows 10. What's wrong?
Any help out there Intel?
JDoya
You should be able to downgrade you drive by going into the device directly and install a new driver and point to the one you downloaded
Note you must go to "Advanced Windows Update" and click the "Defer Updates" checkbox, or Win10 will continually overwrite your driver
I downgraded three versions and they still didn't work (back to Jan 2015). Thanks for the advice on not letting Windows 10 upgrade randomly, but I need one that works first!
JDoya
Try using the driver from your manufacturer
ASpae
New driver for Win 10 released July 28th called Iris Pro includes the 4000.
GZait
AlbertS, please look carefully. I have tried to install this "Iris" driver. It does not include the Intel HD 4000. It does have the 4200, 4600, etc. but not support for the 3rd gen HD 4000.
ASpae
My apologies I have 4th gen 4600. What CPU are you using?
GZait
I specifically have the 3920XM cpu. I don't know what CPUs are used by the rest of this thread.
Anonymous
Not applicable
Update the graphics driver using Microsoft® Windows utility.
Mike C
ASpae
I have done this several times. It still lists the 5 June release of the HD graphics 4000 as the latest driver, and this doesn't work.
Anonymous
Not applicable
The latest graphics driver for Microsoft® Windows 10 is below:
Intel® HD Graphics Driver for Windows® 10 64bit (3rd Gen & BYT)
https://downloadcenter.intel.com/download/25188/Intel-HD-Graphics-Driver-for-Windows-10-64bit-3rd-Gen-BYT- Intel® Download Center
Please reply with the Graphics Report
Right click on desktop> Graphics Properties> Options>Drop Down Menu> Information Center> Save> Attach using
Advanced Editor Options.
Mike C
Allan_J_Intel1
All:
This information is intended to all Windows 10 users that are experiencing issues with a supported Intel® Graphics Controller (http://www.intel.com/support/graphics/sb/CS-034343.htm supported graphics)
/message/321854# 321854 Re: -NEW- Intel® Iris™, Iris™ Pro, and HD Graphics Production Driver for Windows* 10 64-bit 15.40.4.64.4256
See post # 93
Allan.
This is the same driver I tried to use before ***.4256. It still doesn't work. Allen, thanks for your comment and the reference to the other forum. I look forward to Intel bring out a new driver for us
