22799 Discussions
I7-2600K Intel HD Graphics (igdkmd64) Crash Win 7 x64 when using HDMI
Getting frustrated - help please. Every time I try to use an LCD TV (using mobo HDMI-out to TV HDMI-in) it results in a BSOD with STOP 0x16—telling me that the igdkmd64 did not recover. Usually before the BSOD I get something like "Display driver igdkmd64.sys stopped responding and has recovered" several times, and them–KABOOM.
The system works fine with a VGA monitor without the HDMI attached.
This is a clean Win 7x64 (Home Premium) install on a minimal system:
ASUS P8H67 B3 (Realtec HD Audio, and Realtec Gbit Network);
i7 2600K with Intel HD3000 on processor graphics
4 Gb RAM (2x 2Gb) DDR3 1333
HD - Crucial C300 128Gb SSD AHCPI.
Supposedly (?) I have the newest HW drivers
The culprit TV's are an older Olevia 42"-1080i, and a newer 26" VIZIO 1080p. Both are HDCP compliant, and both work fine with HDMI from a DVD, A/V Receiver or cable box.
So far I have tried swapping HDMI cables, tried using a DVI-out to HDMI adapter (TVs don't have DVI ports) – same result. Tried removing one memory stick (leaving only 2Gb on a single slot) same problem. Also tried with various BIOS settings -- no help. The same things happens if I booth in Safe Mode with networking, but not in Safe Mode. So, I disabled the network drivers and devices, and rebooted normally --but didn't help, same BSOD.
Have been searching the web and forums, but nothing seems to be helping.
Any suggestions are much appreciated!
@Leonardo
Where did you got the old driver version? Having the same issue, wanna give it a try...
Thanks!
woha and i thought its a hardware problem, glad to hear thats a driver problem (more or less )
i hope that its fixed very soon. I had similar problems with the new linux drivers but they work like a charm with the newest kernel
Its a cool Effect when i start the pc with vga (normal 19" LCD) it works how it should but when i connect hdmi both screens turn black then i disconnect hdmi and the tft comes back to live, windows says that the driver had a problem. Thats the way i found out thats a driver Problem .
On my 23" LCD from LG works also great over hdmi @1080p but that was only a test my normal system for this pc is:
Windows 7 Professional x64
ASUS P8H67-M EVO
8GB RAM
Epson EH-TW2900
Hello Robert_U,
Any news on the resolution ?
Benoit
ROBERT_U_Intel
No news on a resolution at this time. The issue is still in Debug.
Can someone check ME FW number and Intel Gfx number on failing systems and send back the data? This would be really helpful.
MSchm21
Valued Contributor I
To clarify, did you mean the Video Bios version reported in control center?
I never had this issue, can only give you a working combination for now...
Asrock H67M-B3 Bios 1.40
Video Bios: 2104.0
Driver: all driver versions working
MSchm21
Your forgot the most important video bios version. Open the Intel control menu and go to Support/Info-Center to find it.
ROBERT_U_Intel
If anyone can get the ME Firmware revision,, usually found by running system BIOS Setup and looking in System Information, that would be very helpful.
MSchm21
I'm curious about, what is a ME Firmware revision? Never heard of this.
Found mine on boot screen.
Asrock H67M-B3 1.40
ME Firmware: 7.0.4.1197= working with all drivers (TFT connected via DVI)
Developer and Robert_U,
In my case and I assume most if not all the Asus board owners, we are using below driver from Asus/Intel. Let us know anything we can help. Thank you for all the help.
http://support.asus.com/download.aspx?SLanguage=en&m=P8H67-M%20EVO&p=1&s=39&os=30&hashedid=CkMiq3rrqw3yqO5H http://support.asus.com/download.aspx?SLanguage=en&m=P8H67-M%20EVO&p=1&s=39&os=30&hashedid=CkMiq3rrqw3yqO5H
Version 7.0.0.1118
DescriptionIntel Management Engine Interface V7.0.0.1118 for Windows 32/64bit XP & 32/64bit Vista& 32/64bit 7.File Size251,02 (MBytes)2010.12.29 updateDownload from
Global (DLM) | Global | China | P2P
I'm not sure which number is the ME firmware one but here's some screenshots:
At boot:
http://imageshack.us/photo/my-images/8/img20110519182725.jpg/ http://imageshack.us/photo/my-images/8/img20110519182725.jpg/
http://imageshack.us/photo/my-images/852/img20110519182656.jpg/ http://imageshack.us/photo/my-images/852/img20110519182656.jpg/
System information in bios setup:
http://imageshack.us/photo/my-images/706/img20110519181921.jpg/ http://imageshack.us/photo/my-images/706/img20110519181921.jpg/
I dont know about the video bios info since windows crashes with every driver, and I'm unable to open the Intel control panel.
(using a discrete videocard at the moment)
Asus P8H67-I Deluxe
Core i5 2500K
ME FW 7.0.4.1197
DVI to monitor OK
VGA to TV OK
DVI or HDMI to TV, any other video output is instantly blanked and I have to reboot to recover...
TV is Samsung UE46B8050
Northbridge Intel Sandy Bridge rev. 09
Southbridge Intel H67 rev. B3
Memory Type DDR3
Memory Size 8192 MBytes
Channels Dual
Memory Frequency 665.1 MHz (1:5)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Command Rate (CR) 1T
MCHBAR I/O Base address 0x0FED10000
MCHBAR I/O Size 19456
Manufacturer (ID) Kingston (7F98000000000000)
Size 4096 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number 99U5428-040.A00LF
Intel graphics driver 8.15.10.2361
Version 7.0.0.1118
http://support.asus.com/images/asus_download_pics01.gif Global (DLM) | Global | China | P2P
I'm not at home right now so i can't get into the BIOS to see what my ME version is, but when I built this machine I looked everywhere on intel's sight for the Intel Management Engine download and couldn't find it. I didn't even think to look under utilities on the ASUS sight. I have a P8H67-M EVO board. What does the Intel ME do and should I install it? I can't get anything past the 2219 driver to work without a BSOD, but I'm having no other problems that I know of.
Intel DH67GD (B3) Mainboard
Version: AAG10206-205
BIOS Version: BLH6710H.86A.0076.2010.115.1959
Monitor: Acer AL1706 via DVI.
Same blackscreen problems when connected in HDMI to sony TV:
- Intel I5-2400
- ASUS H67M-Pro
- 16GB G-skill RAM
- Win 7 64 bits SP1
- Sony KDL-32V5500
Everything works fine with drivers 8.15.10.2219 delivered with motherboard CD, since april approximately the drivers install correctly but I only get black screen, have to remove them in safe mode and install again the one from CD.
Previous drivers from january-march worked correctly, but I can not seem to find to find them anywhere... Anyone has an idea where to find the last working drivers ?
Thanks for investigating on the issue INTEL guys, hope you find the problem source soon...
Ben
Want to chime in, same problem here. P8H67 Asus EVO, the latest drivers.
The problem is - I can't go back to the 2 versions prior. That version caused the display to be way too big for my Panasonic 58" Plasma. And custom scale resolution did nothing.
Only XBMC and WMC crash with BSOD. Windows Media Player works fine.
Further to earlier posts re experience on Asus P8H67-I Deluxe m/b: after doing full build of software but excluding the Intel display driver, found system was stable over a couple of day's use (ie just using the Windows default VGA driver). Then installed v2219 of Intel driver. System will work ok for around 30 minutes, then BSOD (using DVI). Found a VGA cable this evening and started pc with VGA output to screen. Was stable maybe 45 minutes, then got BSOD. So suggest issue is not purely related to digital display ports.
Asus P8H67-M EVO
Core I3 2100T
Control panel reports video bios as 2080.0
Bios reports ME version at 7.0.4.1197
Only working driver is version 8.16.10.2219
All other versions tried crash as soon as an HDMI connection is plugged with BSOD referencing igdkmd64. DVI appears to work, but have not tested it for prolonged periods only long enough to roll back the driver because my primary display is a television via HDMI.
Let me know if you need any more information.
Hi Robert,
I have 2 computers with the BSOD problem.
A intel desktopboDH67 GD (B3) with BIOS version BLH6710H.86A.0076.2010.1115.1959.
The other one is a GIGABYTE Motherboard GA-HA65M-D2H-B3 bios version F5
