23680 Discussions
IGCCTray.exe Error
Cplc
Buenos días. Desde hace 1 semana al iniciar Windows 10 aparece  el siguiente error "
Windows no puede encontrar el archivo: "C;\ProgramFiles\WindowsApps\AppUp.IntelGraphicsExperience_1.100.5536.0_x64__8j3e...\IGCCTray.exe"
El sistema sigue funcionando normalmente pero  ¿Como se puede solucionar el error?
Envío el SSU Scan:
# SSU Scan Information
Scan Info:
Version:"3.0.0.2"
Date:"06/26/2024"
Time:"00:00:35.4166133"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Dell Inc."
BIOS Mode:"UEFI"
BIOS Version/Date:"Dell Inc. 1.23.1 , 06/05/2021 12:00 a. m."
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Mobile"
Processor:"Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz , GenuineIntel"
Secure Boot State:"On"
SMBIOS Version:"2.8"
Sound Card:"Realtek Audio"
Sound Card:"Sonido Intel(R) para pantallas"
System Manufacturer:"Dell Inc."
System Model:"Inspiron 13-7368"
System SKU:"073C"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"23.20.16.4973"
- "Intel(R) HD Graphics 520"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1,00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) HD Graphics 520"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=HD+Graphics+520"
CoInstallers:"oem137.inf,iSKLD_w10_DS,Internal,Intel(R) HD Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmd64.sys"
Driver Date:"08/23/2022 09:00 p. m."
Driver Path:"C:\WINDOWS\system32\DriverStore\FileRepository\iigd_dch.inf_amd64_d8bdffa26077ee9a\igdkmd64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"31.0.101.2114"
INF:"oem137.inf"
INF Section:"iSKLD_w10_DS"
Install Date:"Not Available"
Installed Drivers:"C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_d8bdffa26077ee9a\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_d8bdffa26077ee9a\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_d8bdffa26077ee9a\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_d8bdffa26077ee9a\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"11.X"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_1916&SUBSYS_073C1028&REV_07\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"60 Hz"
Refresh Rate - Maximum:"60 Hz"
Refresh Rate - Minimum:"59 Hz"
Resolution:"1600 X 900"
Scan Mode:"Noninterlaced"
Service Name:"igfx"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) HD Graphics Family"
- "Memory"
Physical Memory (Available):"5,32 GB"
Physical Memory (Installed):"12 GB"
Physical Memory (Total):"11,86 GB"
- "BANK 0"
Capacity:"8 GB"
Channel:"DIMM A"
Configured Clock Speed:"2133 MHz"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"SODIMM"
Interleave Position:"First position"
Manufacturer:"80AD000080AD"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"HMA41GS6AFR8N-TF"
Serial Number:"255CE911"
Status:"Not Available"
Type:"Synchronous"
- "BANK 2"
Capacity:"4 GB"
Channel:"DIMM B"
Interleave Position:"Second position"
Part Number:"HMA451S6AFR8N-TF"
Serial Number:"80F096FF"
Type:"Synchronous"
- "Motherboard"
BIOS:"1.23.1, DELL - 1072009"
Caption:"Placa base"
Chipset:"Not Available"
Date:"05/05/2021 09:00 p. m."
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"06DC7D"
Serial Number:"/58TVWB2/CN76206669000S/"
Status:"OK"
Version:"A00"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"21.40.1.0"
- "Bluetooth Device (Personal Area Network)"
Caption:"Bluetooth Device (Personal Area Network)"
CoInstallers:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"bthpan.sys"
Driver Date:"06/21/2006 12:00 a. m."
Driver Path:"C:\WINDOWS\system32\drivers\bthpan.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.19041.3636"
Index:"0003"
INF:"bthpan.inf"
INF Section:"BthPan.Install"
Installed:"Yes"
IP Address:"Not Available"
IP Subnet:"Not Available"
Last Reset:"06/18/2024 12:16 a. m."
MAC Address:"AC:2B:6E:60:D5:28"
Manufacturer:"Microsoft"
Net Connection ID:"Conexión de red Bluetooth"
NetCfgInstanceId:"{CB4ECB6D-7782-4495-A17F-16BC0F779BE5}"
PNP Device ID:"BTH\MS_BTHPAN\6&36E3665&0&2"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Not Available"
Power Management Supported:"No"
Product Type:"Bluetooth Device (Personal Area Network)"
Service Name:"BthPan"
Status:"Enabled"
Type:"Ethernet 802.3"
- "Service Bindings"
Cliente para redes Microsoft:
Controlador de E/S del asignador de detección de topologías de nivel de vínculo:
Controlador de protocolo LLDP de Microsoft:
Habilitar el protocolo de Internet versión 4 (TCP/IPv4):
Habilitar el protocolo de Internet versión 6 (TCP/IPv6):
Respondedor de detección de topologías de nivel de vínculo:
Uso compartido de archivos e impresoras para redes Microsoft:
- "Intel(R) Dual Band Wireless-AC 3165"
Access Point:
Authentication:
- "Caption":"Intel(R) Dual Band Wireless-AC 3165"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Dual+Band+Wireless+AC+3165"
Channel:
Cipher:
Connection Mode:
DHCP Enabled:"Yes"
Driver:"Netwtw04.sys"
Driver Date:"09/07/2023 12:00 a. m."
Driver Path:"C:\WINDOWS\system32\drivers\Netwtw04.sys"
Driver Provider:"Intel"
Driver Version:"19.51.48.1"
Index:"0001"
INF:"oem72.inf"
INF Section:"Install_MPCIEX_DELLM2_3165_AC_HMC_WINT_64_AC"
Installed:"Yes"
MAC Address:"AC:2B:6E:60:D5:24"
Net Connection ID:"Wi-Fi"
NetCfgInstanceId:"{93CE3E36-16C7-4993-9FD5-C92CA8D1656E}"
Network Name:
Network Type:
PNP Device ID:"PCI\VEN_8086&DEV_3165&SUBSYS_44108086&REV_79\AC2B6EFFFF60D52400"
Power Management (Low Power):"Active: Yes, Enable: Yes"
Power Management (Wake On LAN):"Active: Yes, Enable: No"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Product Type:"Intel(R) Dual Band Wireless-AC 3165"
Profile:
Radio Type:
Receive Rate:
Service Name:"Netwtw04"
Signal Strength:
State:
Status:"Enabled"
Transmit Rate:
Programador de paquetes QoS:
- "Settings"
*DeviceSleepOnDisconnect:Suspensión al desconectar WoWLAN:"Desactivado (0)"
*PacketCoalescing:Fusión de paquetes:"Activado (1)"
*PMARPOffload:Descarga ARP para WoWLAN:"Activado (1)"
*PMNSOffload:Descarga NS para WoWLAN:"Activado (1)"
*PMWiFiRekeyOffload:Regeneración de clave GTK para WoWLAN:"Activado (1)"
*WakeOnMagicPacket:Magic Packet de reactivación:"Activado (1)"
*WakeOnPattern:Coincidencia de patrones de reactivación:"Activado (1)"
ChannelWidth24:Ancho de canal para 2,4GHz:"Automático (1)"
ChannelWidth52:Ancho de canal para 5 GHz:"Automático (1)"
CtsToItself:Protección de modo mixto:"RTS/CTS activado (0)"
FatChannelIntolerant:No compatible con canal de 40 MHz:"Desactivado (0)"
IbssTxPower:Potencia de transmisión:"5. Máximo (100)"
IEEE11nMode:Modo inalámbrico 802.11n/ac:"802.11ac (2)"
MIMOPowerSaveMode:Modo de ahorro de energía MIMO:"SMPS automático (0)"
RoamAggressiveness:Agresividad de itinerancia:"3. Mediano (2)"
RoamingPreferredBandType:Banda preferida:"1. Sin preferencias (0)"
ThroughputBoosterEnabled:Impulsar la capacidad de proceso:"Desactivado (0)"
uAPSDSupport:Soporte de U-APSD:"Desactivado (0)"
WirelessMode:Modo inalámbrico 802.11a/b/g:"6. Doble banda 802.11a/b/g (34)"
- "Realtek USB GbE Family Controller #2"
Caption:"Realtek USB GbE Family Controller #2"
Default IP Gateway:"192.168.1.1"
DHCP Enabled:"Yes"
DHCP Lease Expires:"06/26/2024 05:48 p. m."
DHCP Lease Obtained:"06/26/2024 09:48 a. m."
DHCP Server:"192.168.1.1"
Driver:"rtux64w10.sys"
Driver Date:"12/10/2017 12:00 a. m."
Driver Path:"C:\WINDOWS\system32\drivers\rtux64w10.sys"
Driver Provider:"Realtek"
Driver Version:"10.21.1012.2017"
Index:"0013"
INF:"oem92.inf"
INF Section:"RTL8153.ndi.NT"
Installed:"Yes"
IP Address:"192.168.1.49;fe80::d7d9:ed3f:2da4:f9c7;2802:8010:261f:8001:d016:23ec:4470:95c2;2802:8010:261f:8001:aa15:fb47:f657:76a6"
IP Subnet:"255.255.255.0;64;128;64"
MAC Address:"50:3E:AA:D1:46:DB"
Manufacturer:"Realtek"
Net Connection ID:"Ethernet 3"
NetCfgInstanceId:"{3AFCB404-959C-4348-A089-202A5D434270}"
PNP Device ID:"USB\VID_0BDA&PID_8153\000001000000"
Product Type:"Realtek USB GbE Family Controller"
Service Name:"rtux64w10"
Status:"Enabled"
- "Settings"
*FlowControl:Control de flujo:"Rx y Tx activado (3)"
*IPChecksumOffloadIPv4:Descarga de suma de comprobación IPv4:"Rx y Tx activado (3)"
*JumboPacket:Trama Jumbo:"Desactivado (1514)"
*LsoV2IPv4:Descarga de gran envío v2 (IPv4):"Activado (1)"
*LsoV2IPv6:Descarga de gran envío v2 (IPv6):"Activado (1)"
*PMARPOffload:Descarga ARP:"Activado (1)"
*PMNSOffload:Descarga NS:"Activado (1)"
*PriorityVLANTag:Prioridad y VLAN:"Activado (1)"
*SelectiveSuspend:Selective suspend:"Activado (1)"
*SpeedDuplex:Velocidad y Dúplex:"Negociación automática (0)"
*SSIdleTimeout:Selective suspend idle timeout:"5 (5)"
*TCPChecksumOffloadIPv4:Descarga de suma de comprobación TCP (IPv4):"Rx y Tx activado (3)"
*TCPChecksumOffloadIPv6:Descarga de suma de comprobación TCP (IPv6):"Rx y Tx activado (3)"
*UDPChecksumOffloadIPv4:Descarga de suma de comprobación UDP (IPv4):"Rx y Tx activado (3)"
*UDPChecksumOffloadIPv6:Descarga de suma de comprobación UDP (IPv6):"Rx y Tx activado (3)"
*WakeOnMagicPacket:Reactivar en Magic Packet:"Activado (1)"
*WakeOnPattern:Reactivar en coincidencia de patrones:"Activado (1)"
EEE:Ethernet de consumo eficiente de energía:"Activado (1)"
WakeOnLinkChange:Wake on link change:"Activado (1)"
WolShutdownLinkSpeed:Velocidad de enlace WOL y Apagado:"10 Mbps Primero (0)"
- "Operating System"
.Net Framework Version:"2.0,3.0,3.5,4.0,4.8"
Boot Device:"\Device\HarddiskVolume1"
Internet Browser:"Brave, Mozilla Firefox, Google Chrome,126.0, Internet Explorer,11.3636, Microsoft Edge,126.0"
Locale:"Argentina"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 10 Home"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"1,81 GB"
Physical Memory (Available):"5,34 GB"
System Directory:"C:\WINDOWS\system32"
Version:"10.0.19045 Build 19045"
Virtual Memory (Available):"6,04 GB"
Virtual Memory (Total):"13,68 GB"
Windows Directory:"C:\WINDOWS"
- "Installed Updates"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB4562830:"Update [2/26/2021]"
KB4577586:"Update [3/28/2021]"
KB4580325:"Security Update [3/3/2021]"
KB4589212:"Update [3/28/2021]"
KB4598481:"Security Update [2/24/2021]"
KB5000736:"Update [9/23/2021]"
KB5005699:"Security Update [9/14/2021]"
KB5006753:"Update [11/11/2021]"
KB5007273:"Update [12/15/2021]"
KB5011048:"Update [8/13/2023]"
KB5011352:"Security Update [2/10/2022]"
KB5011651:"Update [4/17/2022]"
KB5012170:"Security Update [8/10/2022]"
KB5014032:"Security Update [5/13/2022]"
KB5014035:"Update [6/15/2022]"
KB5014671:"Update [7/13/2022]"
KB5015684:"Update [10/29/2022]"
KB5015895:"Update [8/10/2022]"
KB5016705:"Update [9/13/2022]"
KB5018506:"Update [11/10/2022]"
KB5020372:"Update [12/14/2022]"
KB5022924:"Update [3/15/2023]"
KB5023794:"Update [4/11/2023]"
KB5025315:"Update [4/26/2023]"
KB5026879:"Update [6/14/2023]"
KB5028318:"Update [7/12/2023]"
KB5028380:"Update [8/8/2023]"
KB5028951:"Update [8/9/2023]"
KB5029709:"Update [9/12/2023]"
KB5031539:"Update [10/12/2023]"
KB5032392:"Update [11/15/2023]"
KB5032907:"Update [12/13/2023]"
KB5034224:"Update [2/15/2024]"
KB5036447:"Update [3/13/2024]"
KB5037018:"Security Update [4/10/2024]"
KB5037240:"Update [5/14/2024]"
KB5037587:"Update [5/15/2024]"
KB5037995:"Update [6/12/2024]"
KB5039211:"Security Update [6/12/2024]"
- "Processor"
- "Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 78 Stepping 3"
- "Chipset Name":"Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Core+i7+6500U+CPU+"
CPU Speed:"2,601 GHz"
Current Voltage:"1.6 volts"
Driver:"Not Available"
Driver Date:"04/21/2009 12:00 a. m."
Driver Path:"C:\WINDOWS\system32\drivers\intelppm.sys"
Driver Version:"10.0.19041.4355"
Ext. Family:"Not Available"
Family:"Intel Core™ i7-2760QM"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Level 1 Cache:"2 x 64 KB"
Level 2 Cache:"2 x 512 KB"
Level 3 Cache:"4 MB"
Load:"96%"
Manufacturer:"GenuineIntel"
Model:"78"
Name:"Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz"
Number of Cores:"2"
Number of Cores Enabled:"2"
Number of Logical Processors:"4"
Part Number:"To Be Filled By O.E.M."
Processor ID:"BFEBFBFF000406E3"
Revision:"19971"
Serial Number:"To Be Filled By O.E.M."
Service Name:"intelppm"
Status:"OK"
Stepping:"3"
- "Storage"
- "SanDisk X400 M.2 2280 512GB"
Capablities:"Random Access, Supports Writing, SMART Notification"
Caption:"SanDisk X400 M.2 2280 512GB"
Cylinder - Total:"62260"
Description:"Unidad de disco"
Error Code:"Device is working properly"
Firmware Revision:"X4120012"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Interface Type:"IDE"
Manufacturer:"(Unidades de disco estándar)"
Model:"SanDisk X400 M.2 2280 512GB"
Partitions:"5"
Physical Sector Size:"512"
PNP Device ID:"SCSI\DISK&VEN_SANDISK&PROD_X400\4&29AF4A86&0&000100"
Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
Sectors - Per Track:"63"
Sectors - Total:"1000206900"
Serial Number:"161933440984"
Size – Available:"142,30 GB"
SMART Attributes:"Self-Test: 10 minutes, OK, Short Self-Test: 2 minutes, OK"
Status:"OK"
Tracks - Per Cylinder:"255"
Tracks - Total:"15876300"
- "C:"
Availability:"Not Available"
Caption:"C:"
Compression Method:"Not Compressed"
Description:"Disco fijo local"
File System:"NTFS"
Serial Number:"C8C42E9C"
Size – Available:"54,4522171020508 GB"
Volume Dirty:"No"
- "D:"
Caption:"D:"
File System:"NTFS"
Serial Number:"2613BD7A"
Size – Available:"87,9372978210449 GB"
Volume Dirty:"No"
- "SMART"
0x05 Reallocated Sector Count:0:"0"
0x09 Power-On Hours:26816:"0"
0x0C Power Cycle Count:7149:"0"
0xAF Power Loss Protection Failure:0:"0"
0xB0 Erase Fail Count (chip):0:"0"
0xB1 Wear Range Delta:52:"0"
0xB3 Used Reserved Block Count Total:0:"0"
0xB4 Unused Reserved Block Count Total:20899:"4"
0xB5 Program Fail Count Total:0:"0"
0xB6 Erase Fail Count:0:"0"
0xBB Uncorrectable Error Count:0:"0"
0xC2 Internal Device Temperature:36° C:"0"
0xC3 Hardware ECC Recovered:0:"0"
0xC7 CRC Error Count:9:"0"
0xE6 Drive Life Protection Status:17630960947209:"0"
0xF1 Total LBAs Written:89995307820:"0"
0xF2 Total LBAs Read:136576920408:"0"
...#SSU#...
Senkuchan
Valued Contributor II
