23262 Discussions
IMSM: Paging operation "error" on hard drive
I get occasional "paging errors" on both hard drives of a RAID 0 volume. It used to occur on just the second volume, but now occurs on the first volume as well. This message has been happening since the drives were new.
IMSM keeps reporting this problem.
I'm using an ASUS motherboard with either an ICH9R or 10R controller.
I used Event Viewer to view the details, and it shows an Event ID of 51. From what I read in Microsoft docs, this is not a fatal error. The OS apparently discovers the write problem to the paging file, and deals with it. But would be nice to eliminate this problem.
Status for hard drive 'WD-WCAS86649397' changed from 'Normal' to 'Error occurred'.
System Report:-
Intel RAID Controller: Intel(R) ICH8R/ICH9R/ICH10R SATA RAID Controller
Number of Serial ATA ports: 6
RAID Option ROM Version: 8.0.0.1038
Driver Version: 8.6.0.1007
RAID Plug-In Version: 8.6.0.1007
Language Resource Version of the RAID Plug-In: File not found
Create Volume Wizard Version: 8.6.0.1007
Language Resource Version of the Create Volume Wizard: File not found
Create Volume from Existing Hard Drive Wizard Version: 8.6.0.1007
Language Resource Version of the Create Volume from Existing Hard Drive Wizard: File not found
Modify Volume Wizard Version: 8.6.0.1007
Language Resource Version of the Modify Volume Wizard: File not found
Delete Volume Wizard Version: 8.6.0.1007
Language Resource Version of the Delete Volume Wizard: File not found
ISDI Library Version: 8.6.0.1007
Event Monitor User Notification Tool Version: 8.6.0.1007
Language Resource Version of the Event Monitor User Notification Tool: File not found
Event Monitor Version: 8.6.0.1007
Array_0000
Status: No active migrations
Hard Drive Data Cache Enabled: Yes
Free Space: 0 GB
Number of Hard Drives: 2
Hard Drive Member 1: WDC WD4001ABYS-01YNA0
Hard Drive Member 2: WDC WD4001ABYS-01YNA0
Number of Volumes: 1
Volume Member 1: raidvol0
raidvol0
Status: Normal
System Volume: Yes
Volume Write-Back Cache Enabled: No
RAID Level: RAID 0 (striping)
Strip Size: 128 KB
Physical Sector Size: 512 Bytes
Logical Sector Size: 512 Bytes
Parent Array: Array_0000
Hard Drive 0
Usage: Array member
Status: Error occurred
Device Port: 0
Device Port Location: Internal
Current Serial ATA Transfer Mode: Generation 1
Model: WDC WD4001ABYS-01YNA0
Serial Number: WD-WCAS86649397
Firmware: 59.01D01
Native Command Queuing Support: Yes
Hard Drive 1
Usage: Array member
Status: Normal
Device Port: 5
Serial Number: WD-WCAS86287259
Firmware: 59.01D01
