22649 Discussions
INTEL ARC A770 16GB Missing 10Bit Screen Configuration Option
JEMedia
there is no 10Bit Screen Configuration Option yet.
Driver: 31.0.101.4255
Allerstout
在我的 A770 16G 上,使用 dp 的 sdr 10bit 输出仍然无法实现,我想知道你是如何实现的
SkrikInte
Hey @Allerstout
did you select the 10bit output in Intel Graphics Command Center app?
The option wasn't available before when connecting the monitor through a DP cable.
MUC
Honored Contributor I
Yes, I can confirm that outputting 10-bit color depth with standard dynamic range (SDR) now works with the Arc & Iris Xe Graphics driver 32.0.101.5768 in Windows.
In the screenshot below you can see the following device chain:
The Tiger Lake platform was the first with Iris Xe graphics and was released in 2020.
So this issue seems to be resolved.
