23806 Discussions
INTEL E3845 display issue
HLin
We have developed a model of INTEL E3845's main board, DDI does not use, the display use VGA 。then In theory DDI compensation resistance can disable, but if it disable,it will appear under the UBUNTU system, change the resolution, the system screen is not displayed and can not return.
In the WIN7 system,change the resolution is normal. Why does the DDI compensation resistor affect the display of VGA, and only the issue appear under the UBUNTU system?
Thank you very much for contacting the Intel Communities Team, HB. I will be more than happy to assist you.
In this case, for us to assist you better, please post your inquiry on the https://embedded.communities.intel.com/community/en Intel Embedded Community so our Embedded Team can provide you with further assistance with this issue you are facing.
Antony S.
HLin
Thank you for your information
