23849 Discussions
INTEL GRAPHICS COMMAND CENTER
MSTRDVR1
I have a HP ZBook 17 G3 MOBILE WORKSTATION W/ Intel(R) Core(TM) i5-6440HQ CPU @ 2.60GHz W/ WINDOWS 10 PRO THAT EMPLOYS BOTH Intel(R) HD Graphics 530 @ 1920 x 1080 REFRESH RATE 60 AND A NVIDIA Quadro M3000M @ 1920 x 1080 REFRESH RATE 60 AND FOR UNKNOWN REASON INTEL GRAPHICS COMMAND CENTER NOLONGER FUNCTIONS, IT LAUNCHES FINE BUT SAYS "SOME FEATURES ARE NOT SUPPORTED ON NON INTEL ADAPTERS. IT USE TO WORK FINE, ANY HELP WOULD BE APPRECIATED. I HAVE UNINSTALLED AND REINSTALLED BOTH ADAPTER DRIVERS, I HAVE EVEN REINSTALLED WINDOWS.
AlHill
Do not be afraid to release the CAPS LOCK.
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
[Windows 11 is the new Vista]
