22959 Discussions
INTEL Graphics driver not updating - cpu i5-9400 @2.90GHz
Nckk
Hello, issue's just as the title says: my graphics driver doesn't update.
I've installed the latest version on intel-driver-support -> it doesn't register in my system.
I've also:
manually downloaded the latest drivers (31.0.101.2115 for my system) -> clean download, nothing happened
I've deleted everything by running DDU, installed (clean + normal download), nothing happened
my intel software says:
^ I've had deleted all legacy user interfaces before, but the error keeps coming back.
^ what version is running
v what version should be running
any and all help would be appreciated!
RandyT_Intel
Hi @Nckk,
  • Please provide the SSU log report and share it here so I can review your system's configuration.
  • Could you clarify which specific Intel software you're referring to? Please note that your graphics card is not supported and cannot run the latest Intel Graphics Software formerly known as Intel Graphics Command Center and Intel Arc Control.
Based on the error message, it appears that multiple versions of Intel graphics software are installed on your system, which is likely causing conflicts during detection or installation of version 31.0.101.2115.
  • Have you tried following the instructions in the error message to uninstall previous software versions using the Windows Add/Remove Programs feature?
  • Upon checking, your current version is 26.x, and if you'd like to update, the latest supported version is 31.0.101.2115, which is compatible with your processor’s integrated graphics.
Randy T.
RandyT_Intel
Hi @Nckk,
Randy T.
RandyT_Intel
Hi @Nckk,
Since I haven't heard from you, I will proceed with closing this case. Please note that it will no longer be monitored. However, you may submit a new ticket if you need further assistance in the future.
Randy T.
