Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
This forum offers only peer-to-peer support. Thank you!
Learn more about Developing Games on Intel Graphics
551 Discussions
ImportMemoryWin32HandleEXT unsupported
1zun4
I'm currently trying to convert a d3d11 shared texture (CEF process) to my OpenGL game. This was proven to work on a NVIDIA GPU with their Windows drivers, however, it does not seem to be supported on the Intel GPU driver for Windows.
Issue description:
ImportMemoryWin32HandleEXT on EXT_external_objects_win32 unsupported.
https://registry.khronos.org/OpenGL/extensions/EXT/EXT_external_objects_win32.txt
Log:
[STDERR]: OpenGL error after glImportMemoryWin32HandleEXT: 0x500
[STDOUT]: On accelerated paint called with 1 dirty rects, popup: false
[STDOUT]: Creating new shared texture mapping: handle=0x41d4 size=854x480
[STDOUT]: OpenGL estimated size: 3279360
OpenGL debug message: id=1280, source=API, type=ERROR, severity=HIGH, message='Error has been generated. GL error GL_INVALID_ENUM in (null): (ID: 173538523) Generic error'
Code: https://github.com/CCBlueX/mcef/blob/b6958daa9223595687f4cb157d807bdf137d10b6/src/main/java/net/ccbluex/liquidbounce/mcef/cef/MCEFRenderer.java#L135-L140
ArchieD_Intel
Hi 1zun4,
  • When did the issue start?
  • What are the troubleshooting steps that you tried so far?
  • Is the Resizable Bar enabled?
  • Have you used DDU to completely remove all residual drivers and installed a new one?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
1zun4
Hi @ArchieD_Intel ,
Thank you for the response, but this isn't a driver corruption or hardware configuration issue that can be fixed with DDU or system diagnostics. This is a missing API feature where Intel's OpenGL driver simply doesn't implement the GL_EXT_memory_object_win32 extension for D3D11/D3D12 interoperability, which works fine on NVIDIA hardware. What I need is confirmation from Intel's driver team about whether these OpenGL extensions are planned for implementation, not troubleshooting steps for a broken driver.
ArchieD_Intel
Hi 1zun4,
Thank you for your feedback. I will check this and will get back to you once a resolution is available. Thank you for your patience and understanding.
Archie D.
ArchieD_Intel
Hi 1zun4,
Could you please confirm if you are a game or app developer? Knowing this will help us direct your issue to our dedicated team that specializes in game development-related problems.
Archie D.
Esteban_Intel
Hi @1zun4,
Since this is a duplicate of ImportMemoryWin32HandleEXT unsupported · Issue #1143 · IGCIT/Intel-GPU-Community-Issue-Tracker-IGCIT, we will continue to support you over on GitHub and will close this thread here.
