Hi all.
I bought a new Laptop with an i5 7200U CPU and a Nvidea 950m GPU. It had windows 10 (as expected), so I backed it up and installed windows 7 on top.
Despite the Laptop manufacturers not officially supporting windows 7, I was able to install most drivers without too much problems.
I also installed the windows 7 updates until Kabylake compatibility of course jumped up at the end. The one thing I really need now, is the Intel graphic driver.
I download the drivers on Intel's webpage. Windows 7 is btw. listed under the supported OS's.
But when I try to install, I get this message
"Your computer does not meet the minimum requirement for installing the software."
I should say that I did not install windows 7 as UEFI, but on legacy mode. Could that be it? (Please don't just say yes, unless you are having reason to believe so. It takes many many hours to install everything on a 5400 rpm HDD, including the updates.)
Is there any way I can install intels drivers on Windows 7? Btw. I also tried an older version of the driver, from 2016. Still does not work. Same error message.
The Laptop is an Acer E5 575G
Cheers everyone.
Hello Evil_Hamster,
Thank you for contacting the Intel community.
Windows 10 will be the only operating system supported under Kabylake platform, but also the driver is supported for Windows® 7 – 8.1 but on skylake platform only, you can check at:
https://downloadmirror.intel.com/26772/eng/ReleaseNotes_GFX_154518.4664.pdf https://downloadmirror.intel.com/26772/eng/ReleaseNotes_GFX_154518.4664.pdf
We have seen some customers modifying the INF of the driver to have it work for Windows® 7; however, this is under the customer's responsibility. You can see how some users modified it here:
/thread/110152 https://communities.intel.com/thread/110152
I hope this can help you.
Best wishes,
Ivan.
Hello Evil_Hamster,
Best wishes,
Ivan.
