22827 Discussions
Instalo os gráficos intel UHD porém não instala de novo Intel Arc Control
pnpromos
Boa noite eu desinstalei o Intel Arc Control porém vou voltar a instalar e ele não instala simplesmente mas tem designado ali naquela zona. Que se passa?
AndrewG_Intel
Hello @pnpromos
Por favor, esteja ciente de que eu só posso apoiá-lo no idioma Inglês. Eu usei uma ferramenta de tradução da web para traduzir esta resposta, portanto, pode haver alguma tradução imprecisa.
In order to review this further, could you please provide us with more details?
1- Just to make sure we understand correctly, is the issue/behavior the following?
  • You uninstalled Intel® Arc Control, and when you try to reinstall it, it is not installing on the system. Is this correct? If not, could you please elaborate more on the actual behavior?
2- Please describe the steps/process that you followed to uninstall Intel® Arc Control and the steps that you have tried to reinstall it.
3- Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system:
  • Download the Intel® SSU and save the application on your computer
  • Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click Next and click Save.
  • Once you have saved the file (.txt file), please attach it to your reply.
To upload and attach a file, use the "Drag and drop here or browse files to attach" option below the response textbox.
Andrew G.
AndrewG_Intel
Hello pnpromos
We are checking this thread and we would like to know if you need further assistance. Please do not hesitate to contact us back if you have additional inquiries.
Andrew G.
Alberto_R_Intel
Hello pnpromos, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
