23525 Discussions
Integrated Graphic won't display text during startup
PPhil5
My DZ77GA-70K board with integrated graphics no longer displays startup text. This means I cannot use the text bios setup, or the text boot drive selection screen, or the bios update screen, or the RAID configuration screen. I have tried updating Intel Windows graphics drivers and updating the Bios. I have tested the monitor with another computer and that is fine. Since updating drivers or something else has caused Windows to hang during startup, and I can't see the screen to boot to another drive, so this is not a good situation. I can get into visual bios, but only sometimes does it allow my mouse to work, and when it doesn't it is very difficult to navigate with a keyboard, and I haven't discovered a method to change the non-check box settings by the keyboard.
When the display should show text, the monitor says it has no input and goes to sleep.
Originally the sequence was like this, with fast boot optimization:
Power up computer
Display comes on
Display shows POST text, keys to enter BIOS/Boot selections, etc
Windows graphics shows
Then when text stopped working it was like this:
Power up computer
Screen stays asleep until Windows graphics begin
When I removed the fast boot optimization, it was like this:
Power up computer
monitor is asleep until Intel Graphic displays
Monitor says no input while RAID configuration should blink on
Monitor shows Intel graphic again
Monitor says no input again
By now, Windows hangs, or else it never gets to Windows, I don't know, it just says no input on the monitor and the monitor goes to sleep.
I have tried changing settings in the graphics section of the BIOS setup, changing minimum memory, setting the IGD selection to auto or manual, etc.
Any help would be appreciated.
System:
DZ77GA-70K
Core I5 3550K
2 x 8GB Kingston Ram
Antec Neo ECO 620C power supply
ACER H213H display, HDMI, 1920x1080
Thank you
PPhil5
Actually, I have a Core I5 3570K processor.
Hello, Philip.O:
Thank you for contacting the Intel Communities.
I would like to recommend you the following:
1. Perform a BIOS recovery to the current version:
http://www.intel.com/content/www/us/en/support/boards-and-kits/000005630.html http://www.intel.com/content/www/us/en/support/boards-and-kits/000005630.html
2. Load defaults in the BIOS
3. Clear CMOS by removing the battery for more than 20 minutes.
After following this test the behavior of your system and let us know how it goes.
Esteban C
Hello, Philip.O:
Thought I would just check in and find out if you were able to resolve this problem with the BIOS recovery.
I look forward to hearing from you.
Esteban C
PPhil5
Sorry to not get back to you, Esteban. I was able to get the display to work (at least temporarily) then without resetting the BIOS. I discovered I had knocked the SATA cable off the SSD, which was why the computer didn't boot at all. I put a graphics card in it that now displays the text. I want to remember what you told me, because in the future I want to do a clean install of Win7 to resolve some issues with that, and might as well do a clean install of the BIOS as I do that. Thanks for your help.
Hello, Philip.O:
Great to hear you were able to get the issue fixed after finding that about the SATA cable.
In regards to the BIOS update/recovery, please remember not to jump from a very earlie version of the BIOS to the latest due to the fact that it may harm your system.
If any additional questions or inquiries are present, feel free to contact us back.
Esteban C
