22963 Discussions
Intel 2nd generation drivers for windows 8.1 and windows 10
Tmulh11
Hi when I try to view windows 8.1 driver for grapic card for 2nd generation grapic card it brings up this https://downloadcenter.intel.com/search?keyword=2nd+Generation+Intel%c2%ae+Core%e2%84%a2+Processors+with+Intel%c2%ae+HD+Graphics+3000/2000 https://downloadcenter.intel.com/search?keyword=2nd+Generation+Intel%c2%ae+Core%e2%84%a2+Processors+with+Intel%c2%ae+HD+Graphics+3000/2000 But a few months ago it was showing the actual driver for 2nd generation that you can download please fix it.
And for windows 10. I carnt find the windows 10 driver in windows updates I run the update scan and brings back your computer is up to date I am running windows 10. It shows here https://downloadcenter.intel.com/search?keyword=2nd+Generation+Intel%c2%ae+Core%e2%84%a2+Processors+with+Intel%c2%ae+HD+Graphics+3000/2000 https://downloadcenter.intel.com/search?keyword=2nd+Generation+Intel%c2%ae+Core%e2%84%a2+Processors+with+Intel%c2%ae+HD+Graphics+3000/2000 That windows 10 to get the driver to do it through windows updates. Please make the driver avalible to download from your website. and windows update was moved to settings app no longer in the control panel.
Hans_B_Intel
Hello paladox,
For instructions on how to find the drivers for 2nd generation Intel® Core™ Processors with Intel® HD graphics, you can go here:
https://downloadcenter.intel.com/download/23162/Intel-HD-Graphics-Drivers-for-Intel-Pentium-Processors-and-Intel-Celeron-Processors https://downloadcenter.intel.com/download/23162/Intel-HD-Graphics-Drivers-for-Intel-Pentium-Processors-and-Intel-Celeron-Processors
If you can't find it, let me know your processor model.
Graphics drivers for 2nd Generation Intel® Core™ Processors with Intel® HD Graphics 3000/2000, are not supported for Windows10*
You can check this information here:
Graphics Drivers
Supported Operating Systems
http://www.intel.com/support/graphics/sb/CS-034343.htm http://www.intel.com/support/graphics/sb/CS-034343.htm
Tmulh11
Hi I do follow instruction but for windows 8.1 32-bit I can only see an available driver available to download from your site the 64-bit is only avalible to plantom intel users. But a few months ago it was a driver for 2nd generation grapic driver. 32 bit you can download but please fix 64-bit.
Windows 10 driver according to your site says I have to download through windows update. But I doint think that's right since windows 81 64-bit says same thing and version for that driver is 2.0. But the 32 bit driver for windows 8.1 works and has drivers avalible to download without needing to do it through windows updates. please fix all the links for drivers.
BYara
Then when will latest 2nd generation intel(R) core i5 HD graphics driver for windows 10 OS (64-bit) is available for us... is any other option to install another graphics driver?
IUman
In this case if you have an OEM system I strongly recommend installing the latest drivers from your system manufacturer website and check with them if they have graphics drivers for Windows 8.1 64bit.
We only provide generic drivers and the drivers in your system could be customized based on your system features and specifications.
Unfortunately Graphics drivers for 2nd Generation Intel® Core™ Processors with Intel® HD Graphics 3000/2000, are not supported for Windows10* as mention by hansb_intel above.
