23525 Discussions
Intel 530 graphic card flickering
I have Dell XPS 15 9550, I recently updated to latest driver and display keeps flickering momentarily. It doesn't go black or anything but looks as if brightness goes up and down instantaneously. Happens intermediately with the latest updates. I never noticed this issue with 20.19.15.4331, anything above I noticed this problem.
I have tried installing the Beta version as well and they all cause this flickering issue for me.
Intel Driver:
Beta 15.40.26.4474 - Flickering Issue
15.40.25.4463 - Flickering Issue
15.40.14.4452 - Flickering Issue
Dell's Driver:
20.19.15.4454 - Gamma Level Issue + Flickering Issue
20.19.15.4390 - Gamma Level Issue + Flickering Issue
20.19.15.4331 - No Issue
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Display flickers in normal usage
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%):
Often (51-99%): X
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Dell XPS 15 9550
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?<td style="padding: 0 5.4pt; border-width: 0px 1pt 1pt 0px; border-style: none solid solid none; border-right-color: windowtext; border-bottom-color: windowtext; font-style: in...
Hi Zen0s,
Could you please fill out the information asked on this site, in order to collect to collect more information about the issue you are getting?
/thread/77761 https://communities.intel.com/thread/77761
Hellen.
Hi Zen0s,
It is important to mention that we sell our Intel chipsets and processors to third party manufacturers and they design their own computers with their own features, settings, and capabilities. For that reason they design their own drivers, to meet the exact specifications on their computers.
Your computer is having problems with our generic Intel graphics drivers; the best you can do is installing the customized driver released by the OEM (Original Equipment Manufacturer).
From this point I recommend you to contact Dell* and report to them that you are getting Graphics issues with latest graphics drivers, please mention to them, this is the graphics version that is working as it should on your computer. http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=PFWXP&fileId=3549728728&osCode=WT64A&productCode=xps-15-9550-laptop&categoryId=VI 20.19.15.4331,A04 21 Dec 20156:35:40 AM
Dell* Product Support
http://www.dell.com/support/home/us/en/19/product-support/product/xps-15-9550-laptop/drivers/advanced http://www.dell.com/support/home/us/en/19/product-support/product/xps-15-9550-laptop/drivers/advanced
If this Graphics version works fine on your system I would suggest you to keep using that one.
Hellen.
Generic Intel Graphic Driver and customized Dell driver both show same symptoms
Hi Zen0s,
Please let me investigate about this, I'll let you know the outcome.
Hellen.
Hi Zen0s
Please contact Dell and verify if a BIOS update is required.
According to Dell* Driver Details, BIOS update 01.02.10 fixes LCD flickering when in lowest brightness:
http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=96T2K http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=96T2K
If the issue persists even after updating the BIOS, I recommend you to report this to Dell for further replication from their side.
Please let me know the outcome.
Hellen.
I want to confirm this bug report. Similarly, I noticed that uninstalling the drivers altogether prevents the slight flicker in brightness which happens regularly (+-2 times a minute if I have to guess). Based on this bug report I installed the "20.19.15.4331" drivers which indeed do not have this problem. Dell has released later drivers since, which just like the latest generic drivers (including Beta) cause this issue.
However, now I notice when maximizing windows in Windows 10 the animation is not smooth and stutters. Would have to verify whether the same occurs in the (flickering) latest drivers.
In regards to: "However, now I notice when maximizing windows in Windows 10 the animation is not smooth and stutters. Would have to verify whether the same occurs in the (flickering) latest drivers."
This occurs also with the latest drivers and seems to be an issue with the graphics card merely not being capable of handling application windows which near the size of 4k. I reported this on Microsoft Community (http://answers.microsoft.com/en-us/windows/forum/windows_10-performance/maximizing-window-animation-of-4k-windows-has-a/239553c7-94d3-4556-904f-19238488b28c?tm=1470064729595 http://answers.microsoft.com/en-us/windows/forum/windows_10-performance/maximizing-window-animation-of-4k-windows-has-a/… ) but will also report this as an issue here to verify whether this is a problem on all 4k laptops using the Intel HD 530.
Thanks Whathecode for this information, please let me know any update you get on this matter.
Hellen.
This issue just became a bit more complex on my end. I contacted Dell support since a new issue arose (after I reported on this one): my battery does not seem to be detected properly (although charging and using laptop works). The battery does seem to work fine, but the status indicator is totally broken: Windows currently says 'No battery detected', but likewise at one point I had '400 days of battery left'.
While reporting on the battery issue I also reported on the flickering issue, and they asked me whether the flickering also occurs within the BIOS to identify whether this is a hardware issue or not. I did not expect it to occur, but to my surprise it does!
To double check whether I am not just imagining things in regards to the flickering occurring more with the latest drivers, I reinstalled the latest Dell Intel HD graphics drivers (20.19.15.4454) and instantly within 30s or so I could easily notice it. Likewise, while writing this post I have noticed it over 20 times or so. Thus, it is not solely hardware, and the latest drivers definitely worsen the issue. Earlier today, however, I did also notice the flickering with the older drivers. They thus do not completely eliminate the issue.
Now I am starting to think the two issues might be related, given that there are different levels of brightness associated to being on AC or battery. In the BIOS, however, I set both AC and battery brightness to the same level, and I could still notice occasional flickering. Regardless, I will revisit this flickering issue once my battery problem has been resolved to see whether this could be part of the underlying cause.
I downgraded my BIOS of my XPS 15 9550, and have thus far experienced no more flickering issues, even with the latest drivers. This seems to be a known issue for the XPS 15 9550, as it was tech support which advised me to downgrade. This is also reported on the Dell forum:
http://en.community.dell.com/support-forums/laptop/f/3518/t/19987459/ BIOS UPDATE A10 XPS 15 9550 4K SCREEN TERRIBLE FLICKER - General Hardware - Laptop - Dell Community
The main reason for the brightness flickering might thus not necessarily lie on Intel's end, although it remains interesting to see how both BIOS and graphics driver for Windows seem to affect this issue.
The overall poor 4k Windows 10 performance, however, seems to persist regardless, but I presume is unrelated:
Hi Whathecode,
Thanks for sharing your experience, please let me know if there is something else I could do for you.
Hellen.
sdekl
I'm on an asus mainboard with 530 chipset, a 4k monitor which I run at 60 hz via displayport and I experience the same thing, it flickers like maybe a few times per minute
sjefdeklerk,
Thank you for joining the thread.
Please try the troubleshooting steps provided in the thread, but if the problem persists the best thing to do is to create new thread. This way the next agent will have a better look at your specific scenario, you can add this thread as a reference but I recommend creating a new thread in order to isolate your case.
Amy.
