23812 Discussions
Intel 943GML chipset
Hello can i put in intel 943GML chipset the intel T2450 processor?. Thanks
Short Answer iis YES
Long Answer:
The 943GML Chipset is reported to support:
Intel Core Duo @ 533FSB
Intel Core 2 Duo @ 533 FSB (Fastest T5300)
MUST BE "SOCKET M" not "Socket P"
ensure you have the latest BIOS for your laptop.
NB: There have been reports that Socket M @ 667FSB Intel Core-2-Duo, have worked with the Intel 943GML Chipset aswell
Good Luck
If you want to take the "Socket M @ 667FSB Core-2-Duo" path, ensure you have the latest BIOS.
Your CPU Options for "Socket M @ 667FSB Core-2-Duo" are
1) T5500 2MB Cache
2) T5600 2MB Cache
3) T7200 4MB Cache
4) T7400 4MB Cache
5) T7600 4MB Cache
6) T7600g 4MB Cache
Good Luck
can i used cpu T9600 or T6670,i have old sony VGN-N320E with intel 943GML.help me please.thanks.
thank you buddy.i got in my hand T9600.im gona change right now..im not a professional pc..this is the first time.i hope it work..Thanks and appreciate!!
PSan
Hi. Did the T9600 work in the 943 GML chipset? Also, can I then install a T9900? My laptop model is Satellite A135-S4527. Help, please.
PSan
Is the CPU series T9x00 compatible with this chipset (943GML)? Why didn't Peter C mention it then?
Kevin_M_Intel
Hi sanwablo,
It is important to say that the processor T9900 is a tray version. This means that it is intended to be sold to Computer Manufactures only. So Computer Manufactures design and create their own system with their specifications and sometimes they set limitations on their computers.
Due to this reason, I recommend you contacting Dell to confirm what processors can be used with your computer since this information can be provided by them only.
PSan
Hi kevin_intel. Thanks. It is a Toshiba laptop actually. I already asked and as Peter C said the fastest processor you can put in the chipset is Core 2 Duo T7600, which is socket M and 667FSB. The series T9x00 is incompatible with the 943GML chipset I think, regardless of the manufacturer. I don't know why kuyatsushiro6 said T9600 works in it, being socket P and 1066FSB. It was very confusing.
Kevin_M_Intel
Yes I understand it is confusing but I am sure that Toshiba can provide the processor compatibility list for your system.
