Lenovo X230 Product: 23202TG , Bios: G2ET32WW (1.12 ) , Intel HD graphics 4000 ver 9.18.10.3359.
Applications, like Lenovo solution centre, System updates, HP printers utilities, CHROME, etc. start with empty BLACK window. see the SCREENSHORT ATTACHED.
The colors of movies playback are very pure. Intel Graphics control panel starts "invisible"
Neither updates of Lenovo drivers, Intel HD Graphics driver, Windows 7 help to solve this problem. Please, advise!
Thank you beforehand!
dxdiag output:
System Information
Time of this report: 2/28/2014, 01:55:55
Machine name: SNEF-PS1
Operating System: Windows 7 Профессиональная 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)
Language: Russian (Regional Setting: Russian)
System Manufacturer: LENOVO
System Model: 23202TG
BIOS: Phoenix BIOS SC-T v2.2
Processor: Intel(R) Core(TM) i5-3320M CPU @ 2.60GHz (4 CPUs), ~2.6GHz
Memory: 4096MB RAM
Available OS Memory: 3818MB RAM
Page File: 2824MB used, 4809MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_21FA17AA&REV_09
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Wide viewing angle & High density FlexView Display 1366x768
Monitor Model: unknown
Monitor Id: LEN40E2
Native Mode: 1366 x 768(p) (59.850Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.2843 (English)
Driver Version: 9.17.10.2843
DDI Version: unknown
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 8/24/2012 18:53:42, 12601856 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4226-11CF-1A74-FA01A6C2CD35}
Vendor ID: 0x8086
Device ID: 0x0166
SubSys ID: 0x21FA17AA
Revision ID: 0x0009
Driver Strong Name: oem96.inf:Intel.Mfg.NTamd64:iIVBM0:9.17.10.2843:pci\ven_8086&dev_0166&subsys_21fa17aa
Rank Of Driver: 00E00001
Video Accel:
Deinterlace Caps: n/a
D3D9 Overlay: n/a
DXVA-HD: n/a
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
Sound Devices
Description: Громкоговоритель и наушники (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_17AA21FA&REV_1002
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6914 (English)
WHQL Logo'd: Yes
Date and Size: 5/21/2013 21:50:42, 3425608 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Description: Микрофон (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
DirectInput Devices
Device Name: Мышь
Attached: 1
Controller ID: n/a
Vendor/Produc...
Hi MoscowCat,
I am sorry to hear you are having problems with your Lenovo computer but let me do my best to help you.
Based on the report you have provided, your computer is running an older graphics driver version. I recommend you updating the driver to the latest. You can download it at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23639 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23639
If you get a notification message during the installation that indicates that your computer manufacturer does not allow the installation of generic Intel video drives. You are required to install drivers from your computer manufacturer.
You may try to force the installation of Intel generic drivers by performing manual procedure, see here for instructions:
http://www.intel.com/support/graphics/sb/CS-033915.htm http://www.intel.com/support/graphics/sb/CS-033915.htm
Here you can find the zip version of the video driver:
Besides updating the driver, it is important to update the BIOS in your system and the Management Engine driver but these are provided by Lenovo.
You can find the drivers provided by your Computer Manufacture at the following link:
http://support.lenovo.com/en_US/ http://support.lenovo.com/en_US/
Hi Kevin_intel,
Thank you for your support, but it does not work yet.
I updated UEFI BIOS up to G2ET99WW(2.59) from 2013.12.04
I removed first and install the Intel HD Graphics driver. Now it is 10.18.10.3412 from 2014.01.29.
The problems remain. Even, the Intel graphics control panel (right click on screen) starts "invisible" after Intel banner. lenovo and HP utilities look like empty black windows.
Chrome browser starts normal under MS VGA driver ( intel driver removed) and looks like black window after latest Intel Graphics driver installation. See the photo attached.
It is only me who got this problems?
thank you very much!, because Lenovo community keeps silence for my post.
The new dxdiag:
System Information
Time of this report: 3/1/2014, 15:50:31
Memory: 4096MB RAM
Available OS Memory: 3792MB RAM
Page File: 2431MB used, 5150MB available
DxDiag Notes
Display Devices
DAC type: Internal
Current Mode: 1366 x 768 (32 bit) (50Hz)
Monitor Id: LEN40E2
Native Mode: 1366 x 768(p) (59.998Hz)
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.3412 (English)
Driver Version: 10.18.10.3412
Driver Date/Size: 1/22/2014 14:51:34, 19380224 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x8086
Device ID: 0x0166
Revision ID: 0x0009
Driver Strong Name: oem32.inf:IntelGfx.NTamd64.6.1:iIVBM_w7:10.18.10.3412:pci\ven_8086&dev_0166
Rank Of Driver: 00E62001
Video Accel:
D3D9 Overlay: n/a
DXVA-HD: n/a
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Cap Flags: 0x1
Direc...
I understand your frustration on this. I recommend you running an antivirus in your system or check the windows services. In the worst case, a clean installation of the Operating System may be needed.
@ MoscowCat
When did this issue start occurring on your system? Was there a specific application or driver that was installed resulting in this issue? Do you see the issue with the Lenovo supplied drivers specific for your system found http://support.lenovo.com/en_US/downloads/default.page?selector=expand here? If you could uninstall the Intel HD Graphics driver. version 10.18.10.3412 and install the Lenovo specific graphics driver that would be very useful information.
Robert
