23268 Discussions
Intel 965 Express Chipset Family will not upgrade to the latest drivers.
CCowl1
When I go into the the Intel Driver Utility Update program, it downloads the latest drivers, which is Intel Graphics Media Accelerator Driver for Windows* 7 (64).zip
The current driver I have is 8.15.10.1930. I'm trying to upgrade to 15.12.75.4.64.1930. The download of the drivers is fine, but when I install them, it will be fine for a few minutes. Then all of the sudden, my resolution will start to change and weird characters and pictures appear on my screen for a split second. Then maybe one minute later, it will say that the progress of getting the driver is "Failed". I have tried to do the installation about four times. I am using an Intel 965 Express Chipset Family integrated graphics card, along with an Intel Core 2 Duo 2.0 Ghz. Any help would be appreciated, because I need this driver to play a certain game.
Silvia_L_Intel1
Cooperfive, would you please verify the exact chipset family of your system. Please check this link
http://www.intel.com/support/graphics/sb/CS-009245.htm http://www.intel.com/support/graphics/sb/CS-009245.htm
Could you please attach the DX Diag report for your system?
(Start -> Run -> dxdiag -> Save All Information).
I also recommend you to check if you are running the latest BIOS version available for your system.
PDesr
I have the exact same problem and here are my infos:
Chipset
Detected Chipset:
http://support.intel.com/support/chipsets/sb/CS-025753.htm Intel(R) GM965 Express Chipset
Chipset Components
Memory Controller:
82GM965
I/O Controller:
Intel(R) 82801HBM/HEM I/O controller hub (ICH8M) SATA Controller found in IDE mode
Integrated Graphics:
Intel(R) 965GM Graphics And Memory Controller Hub(GMCH)
and I will check if I am running the latest BIOS version available for my system right away
Can you help me?
Silvia_L_Intel1
BuffaloPatrick, thanks for the information.
The latest graphics driver available for your system will be the following https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18223 Intel® Download Center
I recommend you trying the Manual Driver Installation. Here are the steps: http://www.intel.com/support/graphics/sb/CS-033916.htm Desktop graphics drivers — How to Manually Install a Driver in Microsoft Windows 8* or Windows 8.1*
You would need the zip file to perform the manual installation. https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18231 Intel® Download Center
