23486 Discussions
Intel ARC A750 Sparkle Screen Flickering
DhruvIyengar
I’ve recently been having some issues with my Intel Arc A750 flickering. When idle, around every minute, my monitor will flicker to black, but when playing, it tends to flicker more. Also, if a game is active and then tabbed out, I can see the game flickering through my taskbar (it’s semi transparent), but the whole screen does not flicker, leading me to believe it’s a software issue. The only recent program I installed was ALVR, but it was working for quite a few boots. I have also updated my drivers and tried new monitors/cables. Attached is the video of said flickering (it’s towards the end)
DhannielM_Intel
Hi DhruvIyengar,
Thank you for posting in the community. I have a few questions that could help us assess the situation more accurately. Please answer the following:
  1. Does the flickering only occur after installing ALVR?
  2. To confirm, does the flickering happen even when no applications are open, including browsers?
  3. Have you used Display Driver Uninstaller to completely remove the drivers and then install the latest version?
  4. Did you test the GPU on another computer to see if the flickering persists?
  5. Have you tried using different DP ports on the GPU for testing?
  6. Could you provide the model of your monitor? Are you using the display cable that came with it?
Additionally, to rule out potential issues with the monitor, could you try using a different monitor with the same display cable, and vice versa, for testing?
Dhanniel M.
Earl_Intel
Hi DhruvIyengar,
I wanted to check if you had the chance to review the questions I posted. Please let me know at your earliest convenience so that I can determine the best course of action to resolve this matter.
Earl E.
DhannielM_Intel
Hi DhruvIyengar,
Since I haven't received a response from you, I will proceed to close this inquiry. If you require further assistance, please feel free to submit a new question, as this thread will no longer be monitored. Thank you for your understanding.
Dhanniel M.
