23264 Discussions
Intel ARC B580 in an Asus Prime B650M-A II stuck at 1 PCIE lane and 2.5GT/s
lfav2012
Good day, I bought an Intel ARC B580 to replace a Nvidia Geforce 1660. I have an Asus Prime B650m-A II motherboard. I use Fedora 42 Workstation Linux. I enabled BAR, followed all instructions, and even installed all intel software for Linux, and the card is stuck at 1 PCIE lane and 2.5GT/s. I even consulted Gemini and Mistral, followed every advice, and nothing. What should I do?
JeanetteC_Intel
Hello lfav2012,
To get a better understanding of the issue and be able to provide an effective recommendation, please provide the missing key information here:
1) Can you describe further about the issue when you said "card is stuck at 1 PCIE lane and 2.5GT/s."?
2) Is the issue out-of-the-box or has it worked before it failed?
3) May I know what Intel software for Linux has been installed?
4) What BIOS version is currently installed?
5) PSU specs used on this PC setup.
Additionally, I highly appreciate you sharing your system configuration so I can fully check and provide you with an accurate fix. This could be possible by downloading the Intel® System Support Utility for the Linux* Operating System. You may check the Help Guide for Intel® System Support Utility Process (Linux) on how to generate the log file.
JeanetteC.
JeanetteC_Intel
Hello lfav2012,
Let us know if you have any questions.
JeanetteC.
JeanetteC_Intel
Hello lfav2012,
As I have not heard from you for the past few days, I will proceed in closing this thread. Should you need assistance in the future, please submit a new question as this thread will no longer be monitored.
Sincerely,
JeanetteC.
