23069 Discussions
Intel Arc A750 hardware passthrough in Linux kvm
kcw
My Intel A750 in a Rocky 9 host is unable to boot VMs with the dGPU passthrough after recent OS update. Previously it can boot into guest once per host boot. Seems some kind of vendor power reset software is needed.
The dGPU connected monitor is frozen at boot menu (configured vfio driver with kernal cmdline), an attempt to boot VM will force reboot the host.
Andres_Intel
Hello kcw,
Thank you for posting on the Intel®️ communities. I am sorry to hear that you are having booting issues with your VM using your Intel® Arc™ A750 Graphics, I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
Andres P.
Andres_Intel
Hello kcw,
Andres P.
kcw
The reboot issue seems related to passthrough of a USB controller with a USB hub attached instead. Without the hub the VM can boot once per host boot now. Thanks
Andres_Intel
Hello kcw,
Thank you for your response.
Happy to hear that the issue is fixed, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
