22649 Discussions
Intel Arc A770 显卡可以在ubuntu 24.04上使用吗,显卡挂载的驱动是i915,这正确吗
newbeee
JeanetteC_Intel
Hello newbeee,
Yes, the Intel Arc A770 graphics card can be used on Ubuntu 24.04. The i915 driver is indeed the correct driver for Intel graphics, including the Arc series. However, it's important to ensure that you have the latest version of the driver and kernel to support the Arc A770 fully, as Intel's Arc series may require specific updates for optimal performance and compatibility.
You can check for updates and install the latest drivers using the following steps:
1) Make sure your system is up to date by running:
2) You can install the Intel graphics drivers using the following command:
3) Ensure you are using a kernel version that supports the Arc series. You can check your current kernel version with:
4) Visit Intel's official website or community forums for any specific instructions or updates related to the Arc A770 on Linux.
If you encounter any issues, you may want to consult Ubuntu forums or Intel's support for further assistance.
Sources:
Supported Operating Systems for Intel® Graphics Products
How to Identify & Find Graphics Drivers for Linux*
https://dgpu-docs.intel.com/driver/client/overview.html
I hope this helps.
JeanetteC.
JeanetteC_Intel
Hello newbeee,
请注意,我只能用英语为您提供帮助。我使用网络翻译工具来翻译此回复,因此可能会有一些不准确的翻译。接下来,我将用英语回答您。
Let us know if you have any questions
JeanetteC.
JeanetteC_Intel
Hello newbeee,
Since I haven't received any response from you recently, I will go ahead and close this thread. If you require help in the future, please submit a new inquiry, as this thread will no longer be monitored.
Sincerely,
JeanetteC.
