Ankündigungen
22773 Diskussionen
Intel Arc A770 Phantom Gaming D 8GB OC NO FUNCIONA CON LOS PROGRAMAS DE ADOBE PHOTOSHOP, PREMIERE, A
GUILOPEZN
Einsteiger
1.317Aufrufe
Intel Arc A770 Phantom Gaming D 8GB OC NO FUNCIONA CON LOS PROGRAMAS DE ADOBE PHOTOSHOP, PREMIERE, AFETER EFFECTS EN WIN 10 PRO
No encuentro un driver compatible
6 Antworten
GUILOPEZN
Einsteiger
1.286Aufrufe
MI PLACA MADRE ES Gigabyte Technology Co., Ltd.
Model GA-990FX-GAMING Y UN PROCESADOR AMD FX™-9370 Eight-Core Processor
Hugo_Intel
Mitarbeiter
1.258Aufrufe
Hello GUILOPEZN
Tenga en cuenta que solo puedo brindarle asistencia en inglés. He utilizado una herramienta de traducción web para traducir esta respuesta, por lo que es posible que haya alguna traducción inexacta.
Thank you for posting on the Intel Communities. I know it can be frustrating when your apps are not working as intended, I will be glad to help you.
Please note that your system does not meet the requirements for our Intel® Arc™ A-Series GPUs, the GPUs are only validated in Ryzen 5000 and Ryzen 300 platforms, and all types of issues can happen when requirements are not met, you can check the following article for more information:
Intel® Arc™ A-Series Graphics – Desktop Quick Start Guide
I would like to get your full system specs so we can check the configurations and possible updates that might help with this issue, please share with us a log file from the Intel® System Support Utility.
In addition, please let us know the exact symptoms of your issue, Are the software crashing? Is it a low-performance problem? Are these the only software affected? Are the apps freezing?
Hugo O.
GUILOPEZN
Einsteiger
1.234Aufrufe
Acabo de instalar wondows 11 y está funcionando, pero con lentitud
Hugo_Intel
Mitarbeiter
1.219Aufrufe
Hello GUILOPEZN
I understand that you reinstalled Windows and the system is working now but with low performance, however, I would like to get more detailed so we can provide better troubleshooting steps. Please clarify what exactly you mean by the system is working fine, do you mean the apps you reported(photoshop, premiere, After Effects) are now working fine? As for the reduced performance can you let us know more details?
Hugo O.
Hugo_Intel
Mitarbeiter
1.167Aufrufe
Hello GUILOPEZN
We would appreciate it if you could share with us more details regarding the performance symptoms on your system and the apps experiencing those symptoms.
Hugo O.
Hugo_Intel
Mitarbeiter
1.145Aufrufe
Hello GUILOPEZN
We have not received a response from you so far so we will be closing this thread, if you are still experiencing issues when using your Arc GPU, fell free to open a new topic so we can assist.
Hugo O.
Antworten
