23822 Discussions
Intel Arc B580 Not Working Linux - Ubuntu-MATE
James_Bell
I am struggling to get my Intel ARC B580 operational on my PC. The card is not being detected and cannot be used.
The PC has an AMD Ryzen 9 7900X processor
The operating system is Ubuntu-MATE running on Linux kernel 6.13.4-061304-generic x86_64.
Running Mesa version 'Mesa 25.0~git2502210600.64552d~oibaf~o (git-64552db 2025-02-21 oracular'
The following commands and their outputs are presented beneath.
Command 1:
:~$ glxinfo -B | grep -i device
Return 1:
Device: Mesa Intel(R) Graphics (BMG G21) (0xe20b)
Command 2:
intel_gpu_top
Return 2:
No device filter specified and no discrete/integrated i915 devices found
Setting the environment variable DRI_PRIME = 1 does not work. The only graphics device OpenGL appears to be detecting is my integrated graphics card. For example: glmark2 cannot use the intel card regardless of what DRI_PRIME is set to, it is not detected.
I am using the supported Kernel ( >=6.12 ) for the B580, I also have the Ubuntu drivers installed. I would appreciate any assistance in making my graphics card operational.
Kind regards,
James.
DeancR_Intel
Hi James_Bell,
Thank you for posting in the Community.
I appreciate your efforts in troubleshooting the issue with your Intel Arc B580 graphics card. To assist you better, could you please provide the following information?
  • Was the graphics card working before, or is this a new issue?
  • What is the model of your motherboard?
  • Have you made any recent changes to your system?
Your answers will help us diagnose the problem more accurately. Let me know if you have any questions or need further assistance, I'm here to help.
Dean R.
James_Bell
Thank you for your response.
The entire PC is a new build, all other components are working as intended, graphics card has not yet worked with the PC.
The motherboard model is: MSI PRO B650M-A WIFI
No recent changes to the hardware other than re-seating the graphics card a few times to ensure it wasn't a connection issue. The card is connected to the display monitor via display port.
James.
DeancR_Intel
Hi James_Bell,
Thank you so much for your effort in providing this information. I'll take some time to look into it internally and will get back to you once I have all the necessary details. I really appreciate your help and patience with this matter.
Dean R.
James_Bell
Dear Dean,
I have given up and decided to install Windows - the hardware works as expected now.
No matter what I tried I could not make it work with the previously mentioned linux system.
If you find the solution to the issue it still may be worth posting it here if others may find the solution useful 🙂
Kind regards,
James.
Posihdun
Too make sure did you install the Client GPUs  and ran the ITEL-GRAPHICS-PREVIEW ?
Edit:
Looks like you might need the right version of ubuntu-mate.
-UM 25.04 will be the first version to support that card out-of-the-box.
DeancR_Intel
Hi James_Bell,
I wanted to let you know that the supported operating systems for Intel Arc are currently limited to the following:
  • Ubuntu 22.04
  • Ubuntu 24.04
  • Ubuntu 24.10
Since you're experiencing issues with Ubuntu MATE, it would be best to coordinate with the OS distributor for further assistance regarding the compatibility of the Arc GPU with their OS. This information was also highlighted by @Posihdun. I will be closing the thread as well. If you have any other questions or need further assistance, please feel free to reach out.
Dean R.
