23823 Discussions
The repository 'https://repositories.intel.com/gpu/ubuntu /lts/2350 InRelease' is not signed.
Arrikhan
After updating Ubuntu to 24.04.4, sudo apt udpate returns error.
Attempted to update using instructions from https://dgpu-docs.intel.com/driver/installation.html#ubuntu-install-steps using update steps for existing install which completed, but sudo apt update still fails.
Drivers no longer load.
Err:6 https://repositories.intel.com/gpu/ubuntu /lts/2350 InRelease
403 Forbidden [IP: 65.8.161.112 443]
Hit:7 https://repositories.intel.com/gpu/ubuntu jammy/lts/2350 InRelease
Reading package lists... Done
E: Failed to fetch https://repositories.intel.com/gpu/ubuntu/dists//lts/2350/InRelease 403 Forbidden [IP: 65.8.161.112 443]
E: The repository 'https://repositories.intel.com/gpu/ubuntu /lts/2350 InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Arrikhan
During research discovered drivers are included in Kernel 6.5. Ubuntu 24.04 now supports this kernel.
My current kernel is 5.15.0-113-generic
error noticed in /var/lib/dkms/intel-i915-dkms/1.23.10.43.231129.43/build/make.log
warning: the compiler differs from the one used to build the kernel
The kernel was built by: x86_64-linux-gnu-gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
You are using: gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
Upgraded kernel with following command
sudo apt install linux-generic-hwe-22.04
Kernel now showing as 6.5.0-41-generic
Drivers now loading.
ACarmona_Intel
Hello Arrikhan,
Please generate an SSU report to help us further analyze important details on your system, such as the OS build number, complete model of your system, etc. To generate the SSU report, please refer to the article: Intel® System Support Utility for the Linux Operating System . Please send us the generated SSU.txt file.
We look forward to your response!
Carmona A.
ACarmona_Intel
Hello Arrikhan,
We are checking in with you to see if you already have your SSU, so we can further isolate our issue.
Thank you, and have a great day!
Carmona A.
ACarmona_Intel
Hello Arrikhan,
Again, we are checking in with you to see if you already have your SSU, so we can further isolate our issue.
Carmona A.
ACarmona_Intel
Hello Arrikhan,
We have not heard back from you, so we will close this enquiry now. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Thank you, and have a great day ahead.
Carmona A.
Intel Customer Support Technician
Sahid
I am encountering similar issue but on Debian12
Hit:9 https://apt.repos.intel.com/openvino/2024 ubuntu22 InRelease
Err:10 https://repositories.intel.com/gpu/ubuntu bookworm/lts/2350 InRelease
403 Forbidden [IP: 52.84.66.112 443]
Hit:11 https://apt.repos.intel.com/oneapi all InRelease
E: Failed to fetch https://repositories.intel.com/gpu/ubuntu/dists/bookworm/lts/2350/InRelease 403 Forbidden [IP: 52.84.66.112 443]
E: The repository 'https://repositories.intel.com/gpu/ubuntu bookworm/lts/2350 InRelease' is not signed.
Any solution?
Sahid
same experience with other packages - 2024/2023 ... different IP addresses.
Stuff works - installed alright but not configured.
