23825 Discussions
Intel Arc Control Issue
MattaeoDoig
I recently bought a arc 770 16gb GPU and have gone through every process with the drivers to remove my old ones and install the latest, after installing the latest driver, control panel, and support system i am still having issues.
Whenever I use the hot key or directly open the control panel I cannot click on anything let alone close the overlay ( without alt+I)
I have tried deleting everything via DDU in safe mode multiple time to no avail.
I would truly love a a hand understanding.
Jean_Intel
Hello MattaeoDoig,
Thank you for posting on the Intel️® communities. We understand that your system becomes unresponsive after you open the Intel Arc Control.
  • A video showing the issue behavior you are experiencing.
  • Create system reports using the following applications:
    • Intel® System Support Utility (Intel®️ SSU):
    • Open the application and click "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
  • Intel® Graphics Command Center:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
Jean_Intel
Hello MattaeoDoig,
We hope you are doing fine.
Jean O.
Jean_Intel
Hello MattaeoDoig,
Best regards.
Jean O.
