23526 Discussions
Intel Arc Control prompts [Resizable BAR general-not-supported]
HanGeng
Although [Resizable BAR] and [Above 4G Decoding] are actually enabled in the BIOS,Intel Arc Control prompts [Resizable BAR general-not-supported] and [Automatic system support detection is not available]
I have written to ask the motherboard manufacturer and followed the steps given to try to correct the anomaly, After reinstalling the latest BIOS,the problem remains unsolved
I have sent feedback on this forum before, but for some unknown reason, I do not seem to have the right to reply to anyone. When I log on to the forum and click the reply button, the web page is only refrefied, and the post reply button is also prohibited. Even if I reply by email, the email will be returned
I've attached a few screenshots and a system message log below that I hope will be helpful
MSI SnapShot.jpgMSI Center Screenshot.jpegIntel Arc Control Screenshot.jpgIntel Driver and Support Assistant Screenshot.jpegBIOS Update 2023-03-15.png
Hugo_Intel
Hello HanGeng
Thank you for posting on the Intel Communities. I am sorry to hear that you are experiencing issues with the Resizable BAR status for your Intel® Arc™ A770 Graphics.
This is a known issue that we are currently working on to come up with a solution. The issue is just aesthetic and you can verify the status with third-party software like GPU-Z. You can also, try the following workaround for AMD systems:
  1. Boot into BIOS.
  2. Disable 'Above 4G Decoding' and 'Resizable BAR support' options.
  3. Disable 'Secure Virtual Machine' (SVM) option.
  4. Save and Exit.
  5. Restart the computer.
  6. Boot into BIOS.
  7. Re-enable 'Above 4G Decoding' and 'Resizable BAR support'
  8. Save and Exit.
  9. Restart the computer.
  10. Boot into Windows and verify if Arc Control reports Resizable BAR as supported.
I will be sending the information through a private message to the email registered to your profile in case you cannot reply in this forum.
Hugo O.
Thejas_M_K
I have the same problem in my MSI Thin GF63 004IN Laptop.I have followed the workaround still not showing rebar support in arc control and mine is intel CPU not AMD.
JazzyJazzj
Resizable Bar Disabled Intel 770, Says Unsupported Device. Alienware M18, i9-13900HX.
All conditions are satisfied. GPU-Z simply says Unsupported Device.
How do I Enable it?
I have this problem too (0)
  • Responses(0)
