23833 Discussions
Intel Arc Control
Archeus
Hi, I have an Intel integrated graphics card and generally use my other nvidia card. Intel Driver Support assistant installs Arc Control when updating. My question is, do I need it or can I just uninstall it?
AlHill
You can uninstall it.   However, if you stop using IDSA, you can install the Arc driver manually.  If you do that, and choose custom, you can deselect Arc control.  PLUS you can opt out of the Computing Improvement Program.
