23721 Discussions
Intel Arc Control
Redtash1
I have an Intel I9-12900k and Sparkle A770 GPU. To use Fooocus you have to disable IGPU so it will use A770 GPU which works fine but when I disable the IGPU the Intel Arc Control in performance tuning the fan speed control option completely disappears and changes my custom fan curve and also changes the GPU Temperature limit. As you can see in attached pictures, where you select the different GPU's, when both are enabled fan option is available but when IGPU is disabled the fan curve option completely disappears. Thank you.
Redtash1
Sorry but I no longer have the Arc A770 installed in that computer, so I won't be able to check if it fixed the problem. Thank you.
Felipe_Intel
Thanks for the information. We will proceed to close this thread.
