23525 Discussions
Intel Arc artifact in Metro Exodus:enhanced safe mode
Bill_da_da
I am here to report an artifact regarding the artifact when rendering the water surfaces in Metro: Exodus enhanced edition. THe screenshot is attached. The reason to enable safe mode is that the game will randomly crash in normal mode.(another thread covers this)
Bill Ge
Hugo_Intel
Hello Bill_da_da
Thank you for your post on the Intel Communities.
To further investigate this issue we will need part of the information we asked for in your other thread related to crashes which is the game distribution service and the in-game graphics settings in addition please also let us know if the issue can be reproduced in any water surface area in the game or if it is specific to a certain area on the map.
Hugo O.
Bill_da_da
Hi Hugo,
This is the distribution ID on Steam
The in-game setting is :
Bill Ge
Bill_da_da
The image attached in the original thread is at the VOLGA level. However, I do notice there are artifacts in other water surfaces as well like in the desert level.
Hugo_Intel
Hello Bill_da_da
We will check if this issue can be reproduced from our side. Once we have more information we will let you know and post back.
Hugo O.
Hugo_Intel
Hello Bill_da_da
We wanted to let you know that we are still working on settings up the lab for the reproduction of this issue. Once we have the results or the next steps to troubleshoot this issue we will let you know.
Hugo O.
Hugo_Intel
Hello Bill_da_da
Just wanted to let you know we continue to work on this lab. Thank you for your patience.
Hugo O.
Jean_Intel
Hello Bill_da_da,
Thank you for your patience. We would like to let you know that we have been testing the game with our latest graphics driver, 31.0.101.5186, and so far, we have been unable to encounter the issue. Refer to the following video of our testing.
Let us know your results after installing the latest graphics driver. Remember that it is always recommended to run the Display Driver Uninstaller (DDU) software to eliminate all the previous drivers and leftovers and freshly install the newest drivers.
Best regards
Jean O.
Bill_da_da
Hi Jean,
I already finished playing Metro and never used safe mode again. I am wondering if the problem is system-specific. I also find that other nvidia card users do crash as well so that they will have to use safe mode. But I already uninstalled the game, I will not be able to retest it on my computer now.
Bill Ge
Jean_Intel
Hello Bill_da_da,
We appreciate the information you have provided. Unfortunately, as the game has been uninstalled, we may not be able to continue assisting you with this matter. Please consider reaching out to us again should you encounter any future issues. We will promptly close this thread. If you have any other questions, please submit a new thread, as this one will no longer monitored.
Best regards
Jean O.
