23854 Discussions
Intel Audio Service Crash on every Boot
HEDV0
I've setup some new Lenovo Computer.
Now I've installed the lateste Intel Grafic Driver 26.20.100.7463 and I get on every Boot two Events
Application Error
1000
Name der fehlerhaften Anwendung: IntelAudioService.exe, Version: 1.0.687.0, Zeitstempel: 0x5a1e90a7
Name des fehlerhaften Moduls: ControlModule.dll, Version: 1.0.687.0, Zeitstempel: 0x5a1e908c
Ausnahmecode: 0xc0000005
Fehleroffset: 0x000000000001ee55
ID des fehlerhaften Prozesses: 0xf3c
Startzeit der fehlerhaften Anwendung: 0x01d5a36668fc21e7
Pfad der fehlerhaften Anwendung: C:\WINDOWS\system32\cAVS\Intel(R) Audio Service\IntelAudioService.exe
Pfad des fehlerhaften Moduls: C:\WINDOWS\system32\cAVS\Intel(R) Audio Service\ControlModule.dll
Berichtskennung: 328ed790-7267-4cb2-959d-c6e22d29ed54
Service Control Manager
7034
Dienst "Intel(R) Audio Service" wurde unerwartet beendet.
How can I fix this?
LeonWaksman
  1. Please uninstall the Intel Driver 26.20.100.7463 and reboot your laptop.
  2. Install the latest driver from Lenovo site. In many cases the Intel drivers are customized by the laptop OEM in order to accommodate with its hardware.
Leon
HEDV0
I uninstall the grafic driver 26.20.100.7463.
I uninstall also the Intel audio driver 10.27.0.6
After a reboot I install the latest driver from the lenovo site 26.20.100.6911
This install the audio driver 10.27.0.4.
But the result is the same
Application Error
1000
ID des fehlerhaften Prozesses: 0xedc
Startzeit der fehlerhaften Anwendung: 0x01d5a39711dfc387
7034
Any other solution?
Stefan3D
Upload a crash dump that refers to IntelAudioService.exe from c:\Users\{your name}\AppData\Local\CrashDumps\ or c:\Users\{your name}\AppData\Local\Temp\
Should help an Intel driver developer with debugging.
HEDV0
I found lot of Folders under C:\ProgramData\Microsoft\Windows\WER.
--> see attachment
But Nothing under c:\Users\{your name}\AppData\Local\CrashDumps\
HTH
LeonWaksman
Searched in internet and I've founded report for solution on similar problem https://forums.lenovo.com/t5/Lenovo-All-In-One-AIO-Desktops/AIO-520-24icb-intel-Audio-sevice-IntelAudioService-exe-crashes/m-p/4465609#M12814 . Uninstalling the Intel(R) Dispaly Audio. which is under Sound, Video and game Controller in Device Manager, solved this crash.
Leon
HEDV0
This morning I found this report too.
Now I disable the Service IntelAudioService and all crash are gone.
So somebody from the developer should fix it.
Lewis-H
To modify the audio related services settings:
  1. On your keyboard, press the Windows logo key and R at the same time to invoke the Run box.
  2. Type services.msc and press Enter to open the Services window:
  3. Click Windows Audio, then Restart.
  4. Right-click Windows Audio, then select Properties
  5. Set the Startup to Automatic. Then click Apply > OK
  6. Restart these two services and set the Startup types to Automatic through the same method 4) & 5):
  7. Windows Audio Endpoint Builder
  8. Multimedia Class Scheduler
  9. Try to play a music or a video to see if the audio works.
If it does, congratulations! But if it doesn’t, don’t be frustrated, go on to follow the Solution 2.
Fix 2: Update your audio driver
This problem could also be caused by the old or incorrect audio driver on your Windows 10.
I think this might help you! As I also suffer same problem with my audio driver.
Lewis
