23771 Discussions
Intel Corporation driver update for Intel(R) HD Graphics 3000 - Error 0x800f0246
SSiam
I upgraded to Windows 10. After some windows updates there was a problem with the graphics driver. I switched to safe mode and deleted the driver. But now I'm not able to reinstall it neither through Microsoft update nor from Intel's website. I have the error (Intel Corporation driver update for Intel(R) HD Graphics 3000 - Error 0x800f0246) when I try to update the driver. And I have this message if I try to install the driver from other sources (As you can see I have no installed driver)
Marvin_L_Intel
Hi suhaibsiam,
In order for us to have a better view of the issue you have we would like to know the exact model of your computer so we can verify if there are Windows 10 drivers available for it because from our end there are no drivers for Intel HD Graphics 3000 and Windows 10. You can confirm that on the link below:
http://www.intel.com/support/graphics/sb/CS-034343.htm Graphics Drivers — Supported Operating Systems
We have seen that Windows tries to get a generic driver version so you can have it installed, but when the driver is not available you may encounter with errors during the process.
Thank you in advance for your help on this.
marving_intel
Marvin_L_Intel
Hi suhaibsiam,
marving_intel
