23660 Discussions
Intel DSA for Enterprise
Anit
Greetings,
I'm seeking a method to install driver updates silently using the Intel Driver & Support Assistant (DSA) utility. While the utility is effective for individual use, I'm interested in discovering if there are PowerShell scripts or command-line parameters that can be leveraged to facilitate bulk deployments of driver updates.
If we can identify a PowerShell script or the appropriate command-line parameters for this utility, it would enable us to streamline the deployment of driver updates on a larger scale.
IsaacQ_Intel
Hello @Anit
Thank you for your participation in the Intel® communities. We greatly appreciate your engagement and the opportunity to assist you with your inquiry.
After careful consideration and in alignment with our current development priorities, it has been determined that the specific feature you've inquired about will not be addressed by our developer team this year. While it remains a potential consideration for future development, our resources are currently allocated to other high-priority features and enhancements that better align with our strategic objectives.
Since this particular matter is not actively in development, we will proceed to close this thread. If you have any further questions or require additional information, please feel free to submit a new question. Kindly note that this existing thread will no longer be actively monitored.
Isaac Q.
