23769 Discussions
Intel Display Audio Driver Problem
BHowa2
Hp pavillion Model # : 550-047c purchased Aug 2015
Product # : L9L32AA# ABA
Software Build # : 15AM2RRA605# SABA# DABA Service ID # : 20150702
Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz 12gig ram
Intel(R) HD Graphics 4600
Windows 8.1 Pro with Media Center 64-bit
Intel Display Audio (ver 6.16.0.3161 11/5/2014)
Been in HP's revolving door on this one for the past couple of weeks with no joy despite escalating it to the top level support in HP (at least as high as I can get)
===========The following is repeatable===================
Using only the HDMI output for both video and audio
Intel Display Audio is checked as the default playback device
Outputting HDMI to a Philips TV being used as computer monitor
The following is under Win8.1 using FireFox (currently ver 40.0.2, but
also observed under several FF versions back to 38.x)
HDMI audio output _starts_ and works correctly when viewing something such as a
YouTube video or NetFlix.
HOWEVER, after listening to streaming videos that have audio, if FireFox is
closed or exited with audio in progress, the Pavillion begins
generating a loud constant tone through the speakers being fed by HDMI
output.
This tone will continue uninterrupted unless any of the following takes place;
New audio output is started
A new video with audio is started
Volume Control opened and audio level is clicked
Reopening FireFox does not stop the tone. Subsequently starting a
second video within FireFox with the tone playing DOES stop the tone.
See the attached files for the playback device screen and a wave file of the tone that is generated.
Note that there are TWO Intel Display Audio Drivers showing in Device manager... one for Sound Devices, and the other for Audio Inputs and Outputs
Thanks in advance to your consideration of this submission. Any input or pointers to solutions will be appreciated.
Beverly Howard
Amy_C_Intel
Hello bevhoward,
I performed a test and I could not get the same issue the you're facing (we used this high quality HDMI cable http://www.amazon.com/AUVIO-20-Ft-Speed-Ethernet-Cable/dp/B007Z8420O/ref=sr_1_14?s=electronics&ie=UTF8&qid=1441136980&sr=1-14&keywords=auvio+hdmi+cable http://www.amazon.com/AUVIO-20-Ft-Speed-Ethernet-Cable/dp/B007Z8420O/ref=sr_1_14?s=electronics&ie=UTF8&qid=1441136980&sr…) but I would recommend downloading the latest drivers for your system, here you can find the latest graphics version from https://downloadcenter.intel.com/download/25232/Intel-Iris-Iris-Pro-and-HD-Graphics-Driver-for-Windows-7-8-8-1-64bit Intel® Download Center, additionally check if you have the latest drivers from the HP site http://support.hp.com/sg-en/drivers/selfservice/HP-Pavilion-550-000-Desktop-PC-series/7779690/model/7805472# Z7_3054ICK0KGTE30AQO5O3KA30R1 HP Software and Driver Downloads for HP Printers, Laptops, Desktops and More | HP® Customer Support.
Amy.
BHowa2
Sorry, Amy....
It's an answer, but it did not resolve the problem, so, I unmarked it as "best answer" even though it was the only answer to the post in three and a half years.
I do appreciate you input. Problem solved... the equipment has been replaced 😉
Beverly Howard
