23851 Discussions
Intel® Driver & Support Assistant Scan Failure
displayname9
hello everyone. it's my first post here so i'm sorry if i do anything wrong. Intel® Driver & Support Assistant was working without any problem a couple of hours ago but now when i open it i get a warning: "Failed to scan system for updates. Please click "Refresh Results" to try again." what should i do? thank you.
vanci
I have the same problem...
DRob
Also having the same problem. My system info from Intel SSU attached, any common components?
vanci
Motherboard AsRock (my motherboard is B760 pro D4 wi-fi) Ram - 3200 mhz...
GWR52
Uninstalling & reinstalling  IDSA has not worked.
AMD Ryzen 7 5700X 8-Core / MSI mbd /ARC A750 / 32GB ram/ Win11 pro
SSU attached
displayname9
well all messages are about having the same problem. there isn't any moderator etc. here who can help us about the problem? some of my system informations are: 12th Gen Intel(R) Core(TM) i5-12450H , GenuineIntel / NVIDIA GeForce RTX 4060 Laptop GPU / Physical Memory (Installed):"32 GB" / Microsoft Windows 11 Home Single Language
displayname9
hello guys. now i tried to open it again and its working now and i didn't do anything... maybe you wanna try and tell the result.
vanci
It got better for me too without me doing anything. Maybe there was a problem with the server. But the fact is that everything is fine now.
GWR52
All working fine this morning.
Without any other information it looks like they have fixed / rolled back something on their server side.
