23526 Discussions
Intel® Driver & Support Assistant keeps asking to install new Intel® - Driver Windows* DCH
SergioVallone
I'm experiencing a strange issue.
I had some crash with an error message that says "Device Removed (DRIVER_INTERNAL_ERROR) Intel(R) Iris(R)..."
I was playing with Mass Effect Andromeda, so I followed some advice, which gave me the idea of downloading the latest driver for the Iris Plus Graphics.
Now almost every day or more than once a day, the Intel Driver Support Assistant keeps signaling me to install a new driver.
What can it be?
2andromeda
I got a similar issue simply the assitant asking me to install new driver even after i did,  a day or so later it ask me again, then i check sure enough it manage to revert to drivers from july somehow and the cycle repeats.  I turned on telemtry on purpose to send this kind of info back to you guys, this has been goin on for some time im guessing windows is doing something which means this software just need to get on the same page as windows, shouldnt be that hard no?  Also Bf1 doesnt work anymore, it think the drivers are old after i install the newest ones and freezes.  But reverting to older ones work..  Electronics ARts hasnt said anything about it even the forums there with people with Iris Xe cards reporting the same issue with no fix for almost a year now.  Maybe you can do it intel!  ?
AlHill
This is due to a lack of communication between intel and microsoft, where you (IDSA) installs the latest, and microsoft decides to re-install the older.
Either tell IDSA to ignore the latest, or block the older from Microsoft.
If you want the latest, install it with IDSA, then restart.  Then, block the older by using the microsoft wushowhide tool (attached).  Choose HIDE to hide the older.
Steven_Intel
Hello SergioVallone,
I am sorry you are having issues with the Intel® Driver & Support Assistant. I will be glad to assist you.
Please provide the following information:
  • Were you able to update the driver through IDSA the first time?
  • What is the version IDSA is showing for the graphics driver update?
  • Does the game keep crashing, or was it solved when updating the driver?
Steven G.
SergioVallone
Hello Steven and all,
in the end I managed to install the latest driver and the Intel® Driver & Support Assistant stopped asking me to update the drivers. Moreover it solved the game's crashes and all the issue seems to be resolved.
Thank you all for the support.
Best regards
Sergio
Steven_Intel
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it.
Steven G.
