22940 Discussions
Intel G45 DXVA and Hi10P video.
Hi! I am using laptop with the G45 chipset, it can decode h.264 content with the 8bit depth flawlessly. But when i try to open video with the 10bit depth i get the artefacts. When Intel implement 10bit depth support in DXVA mode in this chipset?
Have you tried decoding with different applications? Apple QuickTime? VLC Media Player?
This players doing decode by software mode and the system load about 100% on 720p content and lagging on 1080p.
As i know linux vaapi is using GPU shaders for the hardware decoding and they can add support for 10bit, but windows realisation of DXVA are closed source and only intel can add 10bit depth support for DXVA.
About 10bit depth you can read here:
http://x264.nl/x264/10bit_01-ateme_pierre_larbier_422_10-bit.pdf http://x264.nl/x264/10bit_01-ateme_pierre_larbier_422_10-bit.pdf
http://x264.nl/x264/10bit_02-ateme-why_does_10bit_save_bandwidth.pdf http://x264.nl/x264/10bit_02-ateme-why_does_10bit_save_bandwidth.pdf
http://x264.nl/x264/10bit_03-422_10_bit_pristine_video_quality.pdf http://x264.nl/x264/10bit_03-422_10_bit_pristine_video_quality.pdf
bump
MEA1
New Contributor II
