23539 Discussions
Intel G5400 not working hdmi
BZ1
I bought motherboard ASUS H310M-E and CPU Intel G5400. Installed windows 10. Before installing driver hdmi port is work. After install driver not working hdmi port, but VGA port working. I downloaded all versions of the drivers from the official Intel site. No version works.
(Sorry, but I do not know English)
BZ1
Thank you. I installed the driver. The hdmi port does not work.
BZ1
Hello, boris_zervu. Thank you for your response.
I would like to know how the connection between the monitor and your system is achieved when using HDMI* (type of cable, adapters, etc..). In addition, please let me know which is the model of your monitor.
Then, have you tried using a different TV or monitor? Also, please update your Windows 10*. You can use this https://www.microsoft.com/en-us/software-download/windows10 Windows 10* update tool in order to do so.
Antony S.
Hello, boris_zervu.
I would like to double check if you were able to perform the troubleshooting steps that I attached to the post above and the results.
Antony S.
Under Contract to Intel Corporation
