23801 Discussions
Intel GPA - issues
VMana1
Folks,
What software can we take traces on and look at the frames in details? I see that Intel GPA doesn't work for the following scenarios :
1) Microsoft Edge
2) Microsoft Office
3) Game - Fortnite - Game stops and warns about cheating 🙂
4) System - Glitches on the desktop screen.
Not sure of others scenarios. I have
  • GPA version 10. 104.153.127.
  • Intel Graphics 620 KBL-R
  • Windows 10 RS4 OS.
Any help will be appreciated to see if I could look at those issues?
AlHill
Provide the exact version and build of your windows 10 OS. RS4 is not adequate.
Doc
Diego_S_Intel
Hello VMana1, Thank you for joining our Intel® communities. If you are referring to frame rates (FPS), there are several options to check or monitor frame rates. For instance, Services such as Steam* have an option under Steam Settings > In-Game tab > Enable the Steam Overlay while in game and then under In-game FPS counter, select where you want the counter located. This will display the FPS rate while game playing. We have the following page that lists several tools and utilities that we use with the Intel® NUCs that you can review; however, you need to confirm the system manufacturer of your system supports these tools and utilities. Diagnostic and Performance Tools for the Intel® NUC https://www.intel.com/content/www/us/en/support/articles/000024102/mini-pcs.html If you are referring to something other than what we provided above, please provide more details about your request. Can you provide any links? We cannot find any reference to GPA version 10.104.153.127 that you mentioned. Also, please provide the following: System or Motherboard Brand/Model: Processor: Graphics Driver version: Diego S. Intel (R) Customer Support Technician Under Contract to Intel (R) Corporation
VMana1
Hi Diego,
As you pointed out FPS is a common metric and easy to obtain. I am looking for more detailed metrics and analysis provided by Frame analyzer as well as detailed GPU metrics like ones here
https://software.intel.com/en-us/gpa-user-guide-for-windows-host-gpu-metrics
also, I am happy to provide the information you need but based on your response it looks like the above apps are supported. also it looks like GPA doesn't play well with Fortnite. Is there a switch I can turn on in GPA or Fortnite to make them work together like other online games.
Below is the output from Graphics monitor:
Operating System:
    Name: Windows 10 (build 17134)
    Locale: en-US
    Secure Boot/Trusted Boot is disabled
CPU Information:
    Architecture: x64
    Cores count: 8
GPU #1 Information:
    Name: NVIDIA GeForce MX150
    Vendor id: 0x10DE
    Product id: 0x1D12
    Stepping: 161
    Driver Version: 23.21.13.8892
    Driver Date: 1-22-2018
GPU #2 Information:
    Name: Intel(R) UHD Graphics 620
    Vendor id: 0x8086
    Product id: 0x5917
    Stepping: 7
    Driver Version: 24.20.100.6286
    Driver Date: 8-15-2018
    Supports GPA instrumentation
Machine:
    Memory: 8066 MB
    Screen: 3000x2000, 32 bit
Graphics Performance Analyzers:
    Version: 18.3.329385
    Installation folder: C:\Program Files\IntelSWTools\GPA\
VMana1
Hi Diego,
any updates?
Diego_S_Intel
Hello VMana1, Thank you for your response. In this case, in order to use or to find additional features regarding our Intel GPA (r), please create and submit a ticket through the right area of support found at: https://software.intel.com/en-us There, one of our community peers will be able to assist you. I hope this helps. Diego S. Intel (R) Customer Support Technician Under Contract to Intel (R) Corporation
