23526 Discussions
Intel GPU driver fail to install on Ubuntu 22.04 LTS
Martin_HZK
OS: Ubuntu  22.04 LTS
Kernel: 6.8.0-52-generic
GPU: Intel Arc A770 (16G)
I follow the official guidance https://dgpu-docs.intel.com/driver/client/overview.html.
But it turns out like this when i do sudo apt update
hzk@xiaoran-x99:/etc/apt/sources.list.d$ sudo apt update
Hit:1 http://mirrors.tuna.tsinghua.edu.cn/ubuntu jammy InRelease
Hit:2 http://security.ubuntu.com/ubuntu jammy-security InRelease
Hit:3 http://mirrors.tuna.tsinghua.edu.cn/ubuntu jammy-updates InRelease
Hit:4 http://mirrors.tuna.tsinghua.edu.cn/ubuntu jammy-backports InRelease
Get:5 https://repositories.intel.com/gpu/ubuntu jammy InRelease [15.4 kB]
Get:6 https://repositories.intel.com/gpu/ubuntu jammy/unified amd64 Packages [205 kB]
Err:6 https://repositories.intel.com/gpu/ubuntu jammy/unified amd64 Packages
  File has unexpected size (215105 != 205030). Mirror sync in progress? [IP: 3.163.189.124 443]
  Hashes of expected file:
   - Filesize:205030 [weak]
   - SHA512:b8491d8ab4d1df6751ad2b9fd6c0f6573ff22b1195aa307d508aa67b3a36ab9ba078ecd4459ef04e9d61b50f0b092d30c6a56af96fab5452a7f3507b873a2490
   - SHA256:7984245f37daa005bfb9f681a8c3b01e2b00af79ad5474e57feaebf4d8c8a5a8
   - SHA1:996332f73f4ceeebc4ac92d3b6c0474112923e4e [weak]
   - MD5Sum:473348bae18799fe1dc18b7c463ab1ce [weak]
  Release file created at: Thu, 06 Feb 2025 16:03:10 +0000
Get:7 https://repositories.intel.com/gpu/ubuntu jammy/unified i386 Packages [64.2 kB]
Err:7 https://repositories.intel.com/gpu/ubuntu jammy/unified i386 Packages
Fetched 15.4 kB in 3s (4,785 B/s)
Reading package lists... Done
E: Failed to fetch https://repositories.intel.com/gpu/ubuntu/dists/jammy/unified/binary-amd64/Packages.gz  File has unexpected size (215105 != 205030). Mirror sync in progress? [IP: 3.163.189.124 443]
E: Failed to fetch https://repositories.intel.com/gpu/ubuntu/dists/jammy/unified/binary-i386/Packages.gz
E: Some index files failed to download. They have been ignored, or old ones used instead.
What is the reason?
JohnM_Intel
Hello Martin_HZK,
Thank you for bringing this concern to the community's attention. Before we delve deeper into investigating this issue, could you please provide the following information to help us better understand the situation?
  • What is the make and model of your motherboard?
  • What is the make and model of your CPU?
  • Is this your first time using Ubuntu?
John Sergio M.
Martin_HZK
intel-c612-chipset, E5 2680V3
No it is not the first time I use Ubuntu. I tried driver installation with Ubuntu 24.04 and that works. But it fails with 22.04.
Do have any public distribution for Linux drivers that we can install with simply downloading deb files?
JohnM_Intel
Hello Martin_HZK,
Thank you for providing the necessary information. However, you omitted the make and model of your motherboard, which I need to verify its compatibility with Ubuntu. Additionally, could you let me know if you are using any graphics cards?
John Sergio M.
Xiaoran007
It is obvious that the apt source update is not related to the hardware. This is clearly a bug caused by the source. I have tested on several devices and have obtained the same error. In fact, the source for 24.04 can be updated as expected. The following are the hardware I have tested:
Dell T5820 workstation, Intel Xeon W-2150B
Lenovo P920 workstation, Intel Xeon Silver 4216
Also, same error inside docker container.
Best wishes,
Ran
JohnM_Intel
Hello Xiaoran007,
I understand the difficulties you're encountering and truly appreciate your patience. To better assist you, I kindly request that you create a new thread for your case. This will help us give your issue the attention it deserves and resolve it more efficiently.
John Sergio M.
JohnM_Intel
Hello Xiaoran007,
I hope you had the chance to review the information I posted. Please let me know at your earliest convenience so that we can determine the best course of action to efficiently resolve this matter.
John Sergio M.
JohnM_Intel
Hello Xiaoran007,
John Sergio M.
