- CPU: Core Ultra 9 275HX
- DGPU: NVidia GeForce RTX 5070 Ti Laptop
- Hybrid GPU Mode: ON
- External display connected to display port (DGPU based on hwinfo64 sensors data - at least while the display is active).
- Intel Display Driver: 32.0.101.8136
- No gaming, just simple office usage.
Log Name: Intel-Gfx-Display-External/GfxDisplayExEventViewer
Source: Intel-Gfx-Display-External
Event ID: 10
Task Category: (5)
Level: Error
Keywords: (128)
User: SYSTEM
Description: The description for Event ID 10 from source Intel-Gfx-Display-External cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
链接已复制
Same issue here:
OS: Windows 11 version 25H2 (26200.7171)
CPU: Intel Core Ultra 9 275HX
dGPU: NVIDIA GeForce RTX 5070 Laptop GPU
Intel Driver version: 32.0.101.8136 and 320.101.8250 (Both are tested with a clean install and DDU cleanup)
Model: MSI Crosshair 16 AI 2025
Event viewer errors:
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">- <Syst - Pastebin.com
Same issue on Dell Pro Max 16 Plus MB16250 with Dell monitor attached to USB-C DP.
Dear Intel, please fix it!
Same here... Has this ever been resolved?
I bought my brand new ASUS laptop ONE WEEK ago and have currently 21808 logs (in the span of ONE WEEK!!!) of the exact same event in the Event Viewer.
ASUS Vivobook Pro 15 N6506CU
Windows 11 Home 25H2
Intel Core Ultra 9 285H
24 GB RAM
Intel Arc 140T (driver version 32.0.101.6554; acc. to Intel Graphics Command Center > System > GPUs)
NVIDIA GeForce RTX 4050 driver version 32.0.15.9174; acc. to Intel Graphics Command Center > System > GPUs // NVIDIA Studio driver 591.74 acc. to NVIDIA GeForce Experience)
The following information was included with the event:
0
268435459
815616
268435456
2000
2415919114
0
The message ID for the desired message could not be found
FWIW, my issues went away after I realized a problem with my setup. I have a portable monitor in my mix of monitors and it's USB-C powered. I was using the wrong USB adapter, so it was only getting 2.1A and not the full 3A the OEM adapter provided. On some occasions it needed more current than it was getting and would glitch. Switching to the OEM adapter alleviated all of my issues.
I have a independently-powered desktop monitor. It is connected via USB-C (DP), and and loses power dozens of times in an hour, up to the point when Windows decides to stop using it.
Going to give a try to 32.0.101.8425.
Many thanks for your answer,
In my case I have no integrated screen and only one external monitor which is connected with HDMI.
I don't use USB-C ports.
Driver version is : 32.0.101.8132
Best regards
Thanks, but the thing is, I do not have any external monitor attached... I forgot to mention that in my post from yesterday. It is just the laptop display, no external monitors whatsoever. And again, it's a 7-day old brand new laptop... INTEL, what is going on?!?
Hi Gabriela, I downloaded and installed that driver (101.8425), which turned out to be a 1.2 GB file that also removed the Intel Graphics Control Center from my device and installed the Intel Graphics Software instead, and there's now also another app called Intel Driver & Support Assistant. None of that is what I wanted and expected, but anyway... The new driver DOES NOT resolve the issue. I installed the driver about half an hour ago, and by now there are 661 new error events (all the same) within 30 minutes!!! And over the last 4 hours since I started working today (old and new driver), there are 2474 event logs!!! In four hours!!! This is insanity. Please fix this because clearly, this new driver didn't improve anything at all.
Most likely windows update reinstalled the old driver after you rebooted.
Go check Device manager and make sure the newest is installed:
I just posted a way of making sure the driver is cleanly installed and windows update does not reinstall an old one.
Slytha
Hi, thanks, but I can confirm without a doubt that the latest driver is installed. Windows update didn't do anything after I installed the Intel driver. Everything is as Gabriela suggested. The latest driver is active on my system and still throws hundreds of errors an hour, all day, every day.
Also thanks for the additional info about group policy, but that is not applicable in my case because Win 11 Home runs on my system.
Intel, fix it. Thanks.
Perhaps you could try a full clean remove and install of the driver via the DDU process in safe mode as I explained.
This will fully clean the old drivers, inlcluding all registry entries, files etc, and fully reset them to clean fabric settings.
I also had other issues with external monitor, but this is Asus related, just as an fyi:
In here you can see my other posts and links, should you have one of these problems.
If all doesnt help, i'll let Intell take over 🙂
Slytha
Hi, thank you very much. I may try the DDU uninstall and do a clean install when I have some time. But this is a 7-day old brand new system without any old driver mess on it... It's weird. Also, as mentioned previously I do not have any external display attached; it's only my laptop display, yet all these errors get logged in the thousands... Something is really not right. Maybe there will be a fix someday...
Hello guys,
Yesterday I installed the driver and after half a day of work I got 12 Error 10 reports, so the reports got reduced.
Today I noticed Windows Update reinstalled an older driver, so I did the following to prevent this (maybe useful for you guys):
- Downloaded DDU from official site: https://www.wagnardsoft.com/content/Download-Display-Driver-Uninstaller-DDU-18140
- Download the latest driver: https://www.intel.com/content/www/us/en/download/785597/intel-arc-graphics-windows.html
- Via Group policy disabled driver updates via Win update: Computer Configuration > Administrative Templates > System > Device Installation > Device Installation Restrictions (Not this is only for Windows 10/11 Pro users, not Home)
- Disabled: The "Advanced Settings" Step -> Press Win + S and type Advanced System Settings, then select View advanced system settings. In the small window that opens, go to the Hardware tab. Click the Device Installation Settings button. Select No (your device might not work as expected). Click Save Changes.
- Disconnect Internet (Wifi and ethernet)
- Reboot into safe mode via (Hold Shift while clicking Restart > Troubleshoot > Advanced > Startup Settings > Restart > Press 4 or 5).
- Ran DDU: Select GPU on the right, then select Intel. Go to Options and make sure the very bottom checkbox ("Prevent download of drivers from 'Windows Update'...") is checked. Click Clean and Restart.
- Once back in normal Windows (still offline), run the Intel installer you downloaded and execute a clean installation and only install the "Intel Graphics Driver", the rest is optional if you have a better Nvidia gpu.
- Reboot the OS
- Recheck GPO and advanced settings are still active to prevent windows update driver installation
- Go to Device Manager and verify the "Driver Version" matches the one you just installed. Once you are sure it's correct, reconnect your internet. Because you set the Group Policy and used DDU's "Prevent Windows Update" toggle, Windows should now leave your driver alone.
- Turn the Internet back on, let windows update search for updates.
Slytha
Hello, same issue here :
DELL TOWER PLUS - Intel® Core™ Ultra 7 265K - without CGU
La description de l’ID d’événement 10 dans la source Intel-Gfx-Display-External est introuvable. Le composant qui a déclenché cet événement n’est pas installé sur l’ordinateur local ou l’installation est endommagée. Vous pouvez installer ou réparer le composant sur l’ordinateur local.
Si l’événement provient d’un autre ordinateur, les informations d’affichage doivent être enregistrées avec l’événement.
Les informations suivantes étaient incluses avec l’événement :
0
268435459
417552
16384
40000
49152
0
32.0.101.8132
L’ID du message désiré est introuvable
Many Thanks
Hi Ogmios,
Thank you for your patience and I'd like to apologize for the delay. Please perform DDU and install the latest driver version 32.0.101.8509.
Please let me know if the issue still persists. If you have any questions, please let us know. Thank you.
Archie D.
Hi Archie,
Thanks for the update, but I will not do that. At least for now. The previous driver I installed directly from Intel - based on the instructions from Gabriela on Jan 23 - caused my device to become much slower and sluggish. It was a massive pain with days wasted to remove that Intel driver with DDU again (which caused other issues), and then install the Intel driver that is provided by ASUS for my device. Because this one works perfectly fine - apart from the thousands of errors this thread is about.
I'll wait and see if someone else installs it, but I will definitely only install it once ASUS provides the update of this new Intel driver.
Thank you.
Hi!
I've installed it and the event viewer error logs went away.
I'm not sure however whether everything has been fixed properly.
The original test of playing a video, then turning off the screen (programmatically, as if the screen would have timed out) might still lead to extra CPU / GPU usage, as I could hear the CPU funs turning on. But I could reproduce this only once.
So I want to wait a few days, and do some more testing before accepting this driver as a solution.
But it's definitely a big improvement.
Hi Ogmios,
Thank you for your update. And confirmation that the issue doesn't persists anymore. I understand that you need more time to test this.
Please let me know if the issue will persist. If you have any questions, please let us know. Thank you.
Hi meiersa78, for us to address your concern and to avoid any confusion, please create a separate thread and one of the supports will be helping you.
Archie D.
Hi Ogmios,
I just wanted to make a follow up if the issue still persists after updating to the latest driver. Your feedback at your earliest convenience would be greatly appreciated. Thank you.
Archie D.
