連結已複製
You need to download and run this utility, and attach the results so an Intel support engineer can assist you:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility for Windows*
Doc
Hello Bably,
Thank you for posting. I am sorry to hear you are having issues with this matter.
Please, remove the current Intel® HD Graphics driver version with the steps below and then proceed to install the recommended driver for your computer model mentioned in these steps.
- Open the Device Manager.
- Expand the Display Adapters section.
- Find the Intel Graphics Driver. The driver can also be called the Intel® Graphics Media Accelerator Driver (Intel® GMA Driver).
- Right-click the Intel Graphics Driver and select Uninstall.
- Select the check box Delete the driver software for this device.
- The system must go through a restart to complete the uninstall process.
- If no older drivers are stored in the system, the graphics controller in device manager should now be listed as 'Microsoft Basic Display Adapter', 'Standard VGA Graphics Adapter' or similar. If not, repeat steps 1 through 6.
- Proceed to install driver https://www.dell.com/support/home/us/en/04/drivers/driversdetails?driverId=J5PT2&osCode=WT64A&productCode=inspiron-15-5559-laptop
Amy C
I have the same problem. I've attached my Intel SSU file. The Windows Event Viewer says that Gfxv4_0.exe (i.e., the Intel Graphics Control Panel) stopped working with an APPCRASH. Here's Problem Details from Windows 10 Security and Maintenance:
Description
Faulting Application Path: C:\Windows\System32\DriverStore\FileRepository\cui_comp.inf_amd64_f7412e3e3404de80\Gfxv4_0.exe
Problem signature
Problem Event Name: APPCRASH
Application Name: Gfxv4_0.exe
Application Version: 8.15.10.5037
Application Timestamp: 5ad79aaa
Fault Module Name: igdrclneo64.dll
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 5a96b19b
Exception Code: c000041d
Exception Offset: 000000000019ee5f
OS Version: 10.0.17134.2.0.0.256.48
Locale ID: 4105
Additional Information 1: 2eb3
Additional Information 2: 2eb306f045eabca89f90a3c90df1e662
Additional Information 3: 482a
Additional Information 4: 482a12ac9ec27754e9321fe577c5b367
Extra information about the problem
Bucket ID: e21b0acde27aeef4b41b202a5518b2ec (1448787071318143724)
Thank you for your help,
DonMac
Follow the same steps above and install the recommended driver for your computer model: https://www.dell.com/support/home/us/en/04/drivers/driversdetails?driverId=MYY4X&osCode=WT64A&productCode=xps-15-9570-laptop Intel UHD Graphics 630 P630 | Dell US
Amy C
Hello Amy,
Thank you. I have some questions. In the steps above you suggest that I should delete display adapters until the computer has only something like "Microsoft Basic Display Adapter", But my computer came from the factory with a second display adapter, which is called "NVIDIA GeForce GTX 1050 Ti". If I want to get down to only the Microsoft adapter, I will need to uninstall the Nvidia adapter.
Are you suggesting that I need to uninstall the device for the Nvidia adapter for things to work properly? Of will everything be okay if simply uninstall all graphics devices that contain the name "Intel"?
Thanks again,
Don Macnaughton
Hello Amy,
Thank you. I've downloaded the file in your link, uninstalled the old adapter (which I had to do twice), and installed the new adapter. Everything is working fine with my three monitors.
However, the Intel Graphics Control Panel isn't present in the list of control panel items. Should it be present? If so, what do you recommend I do to make it present?
Thank you,
Don.
