23806 Discussions
Intel Graphics 620 - Ultrawide Display
Guimbitencourt
Hello there, recently I upgraded my Lenovo Ideapad 320 for a Ideapad S145. I use a 29' Inch LG Ultrawide display to work at home, and it was running fine with 2560x1080 resolutions on my old notebook.
But after I get this new, I can't config to the correctly Resolution, the max setting allowed is 1920x1080. I tried many ways to make this configurations, I tried to upgrade de Intel Graphics Driver, and tried to add a custom resolutions. the Graphic Card is the same from Ideadpad 320 and S145, so I don't know what I should do to fix that. Can someone help me?
If I can't find a solution, I think I will need to get my old notebook back, since part of my productity comes from using this set-up for multi-tasking purposes. Thanks
AlHill
Which Ideapad do you have?  Some have amd processors.
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Guimbitencourt
For some reason the TXT file is not displaying on the Drag and Drop system.
Alberto_Sykes
Guimbitencourt, Thank you for posting in the Intel® Communities Support.
I just wanted to check if the issue persists and if you still need technical assistance on this matter?
Albert R.
Guimbitencourt
Hello there, I still have the same Issue.
I aready upgrade de drivers all the time, search everywhere, and I still don't find any answer, since my oldest Lenovo works perfectly with my ultrawide display, but this new doesn't.
Also I have a Desktop which works fine with the same display, so I really don't know what I need to do just to reach the correct resolution,
Alberto_Sykes
Guimbitencourt, Thank you very much for your response, we will be more than glad to assist you in trying to fix this problem.
We are sorry to hear the issue still persists after all the drivers were updated, at this point what we need is to confirm the details about the platform that you are using, so, please provide the SSU report, once you run the report it will allow you to save the information as a text file so you can attach it by drag and drop to this thread, it should be working now:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
We will also need the Intel® Graphics report from your system, please run it while the monitor in question is attached to the new computer, you will also be able to save it as a text file as well to post it on this forum:
https://www.intel.com/content/www/us/en/support/articles/000005848/graphics.html
Albert R.
Guimbitencourt
Here we go. I'm sending the asked informations.
I hope we can fix this as soon as possible, I'm stuck with this problem for months and it's been dificult to use 1920x1080 resolution with the ultrawide.
Thanks!
Alberto_Sykes
Guimbitencourt, Thank you very much for providing the picture and the Intel® Graphics report.
Based on the Intel® Graphics report we can confirm that in fact the 29' Inch LG Ultrawide display supports the 2560x1080 resolution. We can also see in the SSU picture, that the Graphics driver being used is version 27.20.100.9126.
Just to let you know, we always recommend to install the graphics driver provided by the manufacturer of the computer, since that driver was customized by them to work with your specific platform.
I looked in Lenovo's web site and actually, the latest Graphics driver they have available in there is version 26.20.100.7870, please try a clean installation of that driver following the instructions in the link below:
https://pcsupport.lenovo.com/us/en/products/laptops-and-netbooks/ideapad-s-series-netbooks/s145-15iwl/downloads/driver-list/component?name=Display%20and%20Video%20Graphics
If the problem persists after that, then try a clean installation again this time of the latest Intel® Graphics driver for the Intel® UHD Graphics 620 controller which is version 27.20.100.9168 and once you get the chance, please let us know the results:
https://downloadcenter.intel.com/download/30148/Intel-Graphics-Windows-10-DCH-Drivers
Albert R.
Alberto_Sykes
Hello Guimbitencourt, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Alberto_Sykes
Hello Guimbitencourt, Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
