23648 Discussions
Intel Graphics 630 problem with the 3d graph, when I use VJ software Resolume.
AKirk1
Hello.
My laptop is pretty good and new:
https://www.asus.com/bg/Laptops/ASUS-VivoBook-Pro-15-N580VD/
with 16Gb RAM memory,
Nvidia GeForce GTX 1050 Dedicated video memory 4Gb.
I chose it specially to can use it with Resolume.
But there is some issue and when I see the Task Manager
the problem is with the [b]GPU of Intel(R) HD Graphics 630 - the 3D graph[/b].
And the parameters are getting over 90%,
when I work with Resolume,
with not so big resolutions.
My visual files and the configurations are just HD.
And the problem comes for example when I play videos on only 2 layers for 15-20mins.
Any ideas and suggestions?
Maybe some settings of the Intel Graphics have to be changed?
Thank you for the attention.
Hello, Quantum-Space. Thank you very much for contacting the Intel Communities Team. I will be more than happy to assist you.
By checking the https://resolume.com/software/specs minimum requirements of the Resolume VJ I can see that the Graphics controller should be at least Intel® Iris® Pro, AMD* or NVIDIA* also, the recommended specs suggest having a discrete NVIDIA* GTX 1080 or AMD* Radeon™ Pro 450 card, therefore, the results you are having are expected with the Intel® HD Graphics 630 controller since it does not meet the requirements that the software needs.
I suggest you to keep using the NVIDIA* card that your system has in order to use the Resolume VJ.
Antony S.
AKirk1
Thank you for the answer,
I will do it.
