23780 Discussions
Intel Graphics Card Surface Pro 2
LF2
I am very confused here. I go on the website and search for graphic drivers for my surface pro 2. It comes up with a driver for the 4th gen 4400 graphic card:
Driver Version: 15.40.10.64.4300
DATE: October 16, 2015
When I go to my actual driver on the my system, it is model number 10.18.15.4256 with the date of 7/17/2015.
Which means I should be able to update my driver right?
I cant, doesn't allow me says system is not compatible. Also why cant I find my intel graphics control panel to open so I can adjust settings for my monitor?
Need some answers please. Am I with the up to date driver for my SP2 for 2016?
If so how can I get my intel graphics panel up for adjustments?
windows 10, most current build
Amy_C_Intel
Hello, LouieLou16:
In this case the drivers for your device should be provided by your computer manufacturer that is the reason why you are getting this error message, check with Microsoft if there are new driver releases for your device.
Amy.
