23083 Discussions
ig75icd32.dll (Intel OpenGL graphics driver) crashes when used by Java applications
JBeck15
I've been trying to find a solution for this driver crash for the past couple of days: when I run any libgdx-based program (Java OpenGL-based), or Corona SDK Simulator (a different Java-based OpenGL program), the programs crash. The crash is coming from ig75icd32.dll, which is shown from the native stack trace:
system: Windows 7 Professional SP1, 64-bit
processor: Intel(R) Core(TM) i7-4510U CPU @ 2.00GHz
graphics: Intel HD
RAM: 8GB
I tried upgrading my graphics drivers (they are up-to-date), Windows update, etc., used Java versions 6 (32- and 64-bit), 7, and 8 with the programs. Always the same crash. However I was able to start one of them in full-screen mode, until the app loses and then regains focus, upon which the same crash occurs.
error stack trace (given by Java Virtual Machine), where top is the innermost call, from OpenGL32.dll to ig75icd32.dll:
Stack: [0x06120000,0x06170000], sp=0x0616f298, free space=316k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [ig75icd32.dll+0x12ad6b]
C [ig75icd32.dll+0x12aeb2]
C [ig75icd32.dll+0x2f6fcd]
C [ig75icd32.dll+0x128123]
C [ig75icd32.dll+0x12a5af]
C [ig75icd32.dll+0x12aac8]
C [ig75icd32.dll+0x96b80]
C [ig75icd32.dll+0x3a7066]
C [OPENGL32.dll+0x39422]
C [OPENGL32.dll+0x395e9]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.lwjgl.opengl.WindowsContextImplementation.nCreate(Ljava/nio/ByteBuffer;Ljava/nio/IntBuffer;Ljava/nio/ByteBuffer;)Ljava/nio/ByteBuffer;+0
j org.lwjgl.opengl.WindowsContextImplementation.create(Lorg/lwjgl/opengl/PeerInfo;Ljava/nio/IntBuffer;Ljava/nio/ByteBuffer;)Ljava/nio/ByteBuffer;+10
j org.lwjgl.opengl.ContextGL.(Lorg/lwjgl/opengl/PeerInfo;Lorg/lwjgl/opengl/ContextAttribs;Lorg/lwjgl/opengl/ContextGL;)V+103
j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;Lorg/lwjgl/opengl/Drawable;Lorg/lwjgl/opengl/ContextAttribs;)V+102
j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;Lorg/lwjgl/opengl/ContextAttribs;)V+9
j com.badlogic.gdx.backends.lwjgl.LwjglGraphics.createDisplayPixelFormat(ZII)V+83
j com.badlogic.gdx.backends.lwjgl.LwjglGraphics.setupDisplay()V+470
j com.badlogic.gdx.backends.lwjgl.LwjglApplication.mainLoop()V+9
j com.badlogic.gdx.backends.lwjgl.LwjglApplication$1.run()V+27
v ~StubRoutines::call_stub
Amy_C_Intel
Hello, voxoid.com:
Could you please let us know the driver version you are running? Please go to Device Manger> Display adapters> Intel(R) HD Graphics right click on Properties and then go to Driver, you will be able to see the version installed.
Amy.
