23569 Discusiones
Intel Graphics Command Center Service Not Removing
KripTed
Principiante
6.181 Vistas
After uninstalling the Intel Graphics Command Center the service is still there and continues to run even after uninstallation. How do I completely get rid of this? I tried to install the one from the Microsoft Store and it just makes a new service. I end up having two services running. The legacy/original one that downloaded from Windows when I enabled my onboard display through the BIOS is still there. I uninstalled that one and the service never went away. It also doesn't even show up in the startup tab under task manager. The one from the Microsoft Store gets removed fine. Anyone have any ideas?
0 kudos
1 Solución
KripTed
Principiante
6.167 Vistas
Figured it out. For anyone else who experiences this problem here is a fix to get rid of the service completely.
Open Regedit
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\
Look for the Intel Graphics Command Center service and delete the folder.
Restart your PC.
Someone should probably still look into this though.
Ver la solución en mensaje original publicado
2 Respuestas
KripTed
Principiante
6.168 Vistas
Open Regedit
Restart your PC.
Jose_Intel
Empleados
6.144 Vistas
Hello @KripTed
Thank you for posting on the Intel️® communities.
We are glad to know you found a solution for the issue with the service, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing a similar behavior.
Since the thread is now solved, we will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
Jose B.
Responder
